gil
Flight distance : 1379308 ft
Hmm, if you're really lucky you might be able to correct this with a simple fix. In the Phantom battery compartment, make sure the little push pins on the internal plug move freely and extend the full travel. Make sure they are clean (a rubber eraser works well for this). Next, make sure the battery is fully inserted in the battery compartment. (photo shows a P2 series btry, P3 series has 4 pins) |
