dobmatt
Flight distance : 1831050 ft
Rinzler, apparently 3rd attempt to calibrate this stubborn TB47 did the job. The warning message disappeared, battery seems to be at full capacity and cells voltage equalized to within .01V. I performed this silly low hovering to discharge, observing cells voltage ... I removed the X5 gimbal just in case and that was a mistake: at 10% Inspire was forced to land and to dissipate the remaining power down to 3.3V/cell without camera load took 3 agonizing hours!
Anyway, at the beginning of "discharge by hovering" the cells voltage was a bit too off to my taste, displaying .06V difference between the lowest and the highest bar. The differencies start to dissappear pretty fast, however, showing more equal voltage per cell at approx. 75% capacity. At 10% Lady Voice announced Critically Low Battery and the bird was forced to land. At 5% green bars dropped abruptly from +/- 3.71V to a red very bottom, Lady Voice warned again about CLB, and green bars appeared again at 3.71V. Interestingly the Lady was silent during two previous deep discharging procedures. This time she was very active with CLB warnings every time the capacity dropped by 1% and later several times randomly during discharge below 0%. At 3.50V the bars were changing color from yellow to red, showing approx. .05V differencies across. The battery shut off with 3.20V on first cell and 3.32 on second as the lowest and the highest value.
I hope the Angel battery managing devices will arrive soon before I'll go nuts calibrating other batts ...
