Battery Firmware
bryn1
Hi all, I am currently running on firmware 1.8 in the aircraft and do not wish at this point to upgrade, however I have just purchased a new battery and would like to ensure that it's firmware matches my other batteries.
I tried to find the info on the DJI website but could not locate it so my questions:
Which firmware would I need to load onto my SD card to enable me to update/ensure the same firmware gets loaded onto the new battery as is on my other batteries without having to update the aircraft as I am happy running the aircraft on 1.8 and do not want to go to 1.9 yet
I know that not all firmware releases include an update for the battery so which was the last firmware revision that also included a battery update? was it 1.7?
Hope my ramblings make sense?
Bryn.
2016-8-4
robtaylor28
you will have to read the notes for all updates from the update your using and b4 to see which has the last battery update. the latest update is only for no fly zones and batteries so you could just update all either
2016-8-4
DJI-Paladin
Flight distance : 2408 ft
Hello Bryn, when a battery needs an update, you'll see a notification in the app saying " battery needs to be upgraded" in Overall status. And It is recommended to keep all the firmware up to date to ensure the user experience. If your drone is 1.8 fw and you don't want to update to 1.9, you can extract the 1.8 bin file to the card and give it a try.
2016-8-4
PoppaHotel
Flight distance : 39600 ft
DJI-Paladin Posted at 2016-8-4 21:54
How do I upgrade firmware in spare batteries?  Documentation please.
2016-12-12
