DJI-Ken
Flight distance : 1515312 ft
I see the aircraft moving in tiny circles, have you done a proper IMU and compass calibration?
And I see in one of your flights it going into P-Opti and losing GPS but still having many satellites.
Do the calibrations and try in a different location. I also see those big power lines right next to your backyard. That may be causing some interference.
So, do the calibrations again and try a different area. I'm thinking you will be fine. If not, then reapply the firmware and see if that helps. If not, then continue with the ticket and they will send you a shipping label.
