http://wiki.dji.com/en/index.php ... brating_the_Compass
Calibration Procedures
Choose an open area to carry out the following procedures.
1. Ensure that the compass is calibrated. If you did not calibrate the compass as part of your pre-flight preparations, or if you have moved to a new location since the last calibration, tap the Aircraft Status Bar in the app and select “Calibrate”, then follow the on-screen instructions.
2. Hold the aircraft horizontally and rotate 360 degrees. The Aircraft Status Indicators will display a solid green light.
Tips: Calibrate the compass before each flight. Launch the DJI Pilot app and follow the on-screen instructions to calibrate the compass. DO NOT calibrate the compass near metal objects such as a metal bridge, cars, scaffolding. When to Recalibrate 1.When compass data is abnormal and the Aircraft Status Indicator is blinking green and yellow. 2.When flying in a new location or in a location that is different from the most recent flight. 3.When the mechanical or physical structure of the Phantom 3 Professional has been changed. 4.When severe drifting occurs in flight, i.e. Phantom 3 Professional does not fly in straight line.
