dgriffnz
Flight distance : 170988 ft
New Zealand
check out my Shaky Bridge video on my You Tube channel (http://www.youtube.com/dgriffnz).
It clearly shows what seems to be an all too common fault with the Phantom cameras - out of focus, blurry sections from the lens.
If you watch the video in 1080p @ 0:50 you can see the chain link fence clearly at both ends of the bridge...however, the centre of the bridge is out of focus and shows no detail at all.
Settings:
Nd8 polar pro
Dlog uhd 30fps -2-1-1
Air temp 04c
Slight sharpening post production with Sony Vegas Pro that failed to bring in more definition.
The filter and lens are spotlessly clean. I will recheck and ensure the nd8 is on as tight as I dare in case it had worked itself loose, but reading these forums I think there is enough evidence that this is now becoming a common DJI issue.
