Hi everyone, I've noticed when tilting the camera (Zenmuse X3) on my Inspire 1, sometimes I get a weird sort of noise/aliasing/artifcating ()...is this normal? It was recently in a crash, so I'm trying to figure out if the camera is somehow damaged or this is just normal.
You will need to slow the gimbal speed down to eliminate the motion-blur and pixelation effect. I have mine set at 40, there are other threads with screen shots for adjusting the camera and gimbal.
Turn Auto Exposure off and manually set your camera for better results too.
Some aliasing can happen when there are fast yaw movements, but it should not be excessive. Since you had experienced a crash, you may want to look into a repair service.
