DJO wont work on Samsung Galaxy Tab Pro 10.1?
2982 10 2016-8-17
northwesten
Hi
So I am a little confused because I was able to install the DJI Go app on my  Samsung Galaxy Tab Pro 10.1. It worked at first but then I found my tablet was getting a little slow.  Now I did a factory reset to clear a lot of the app I had. Now I am unable to install the DJI Go app on this nice table?
What has changed? Why do I have a feeling that DJI is heavly in favor of the Apple product? I will never ever by Apple and this I found unfair that Androud seems to getting scewed? The pro tablet has enough hardware to do this..
Pete
2016-8-17
DJI-Paladin
Flight distance : 2408 ft
Hello Pete, please check this option and make sure the app has been downloaded from Google play
Enabling installation of third party apps on an Android:
Go to Settings on your phone and switch to the “general” tab, if needed.
Tap on the “Security” option.
Tick the checkbox next to the “Unknown Sources” option.
Confirm the warning message by tapping on “OK”.
2016-8-17
labroides
Flight distance : 26781877 ft
http://forum.dji.com/forum.php?m ... 4&fromuid=10818
2016-8-17
Cetaman
Flight distance : 2528264 ft
Aloha Pete,
     The Samsung Galaxy Tab Pro 10.1 works very well and even fits inside the device bracket (barely).  BTW, protect the foam on your device bracket by putting painter's tape over the foam so the tablet slides in and out easier and does not eat up the foam.  You will also have to open up the USB access slot in the bottom device bracket a little bit.  I used a Dremel Moto Tool.  (Be careful, it can gt away from you.)  I have been using my Galaxy for over a year now and it is still going strong.  And the display is great if you disable all the competing apps.
     Paladin and labroides are giving you good advice.  Persevere, and you will have an enjoyable and entertaining experience with your Galaxy Tab Pro 10.1 just like I do.  This forum is loaded with good suggestions on how to improve performance.  Use the Forum search function to look up your tablet and read what is said in the threads.  One problem I have had is with Remote Controller updates.  When they go through the device, the Galaxy does not like to do the job.  I use my Galaxy cell phone (also loaded with DJI GO) to do the job for the tablet and it works just fine afterward.  I hope this helps!
Aloha and Drone On!
2016-8-17
toddsa1
Flight distance : 1871276 ft
Cetaman Posted at 2016-8-18 15:49
Aloha Pete,
     The Samsung Galaxy Tab Pro 10.1 works very well and even fits inside the device br ...
I use Samsung note pro 12.2  BEST one Yet ! I Even Bought A Samsung Galaxy View  18 in. TAB
But No Go App , Just Litchi .
     I also  have the 10.1 note ,, just think its too old ,,had them both rooted ,, because of bloatware ,, and bad battery life ,,
2016-9-13
JWC P4
Flight distance : 8176 ft
South Africa
toddsa1 Posted at 2016-9-14 07:44
But N ...
How do you fit the Note Pro 12.2 on your remote controller??
2016-9-14
jwt873
Flight distance : 6754350 ft
You can buy extenders that increase the size of the RC mount...    Here's one --> http://www.dsstyles.com/product/ ... or-ipad_p2000038078  But, there are many others if you shop around.
2016-9-14
JWC P4
South Africa
jwt873@gmail.co Posted at 2016-9-14 14:02
You can buy extenders that increase the size of the RC mount...    Here's one --> http://www.dsstyle ...
WOW - many thanks for this!!  Will get some for my tablet as I like the big format screen.
2016-9-14
lone droner
JWC P4 Posted at 2016-9-14 20:07
But do not forget the 12.2 is a battery hog it will Always use more energy that it could put it back in while  you r  charging it.
Samsung has a problem with that, touch wiz  sucks .. lots of juice,, rooting is cheap. try it !
but I do have the big screen it is awesome ,because I do not like Apple it just is terrible the DJI prefers Apple over Samsung
2016-9-14
Skip707
Todd SA1, I have a Samsung note 10.1 will this work on dji phantom 4 pro controller? Thanks
2017-4-15
Skip707
toddsa1 Posted at 2016-9-13 21:44
Does anyone know if the 2012 Samsung note 10.1 will fit and is compatible with phanton 4 pro controller? Thanks
2017-4-15
