Heebus
you should hear home point pointed on the map, please check map to insure its correct... this is the app setting your home point, where you took off
make sure to set you RTH ( return to home ) height in the app, enable smart return home, and when you lose signal it will go up to the height you set in the app, and return home to where it took off. You have a RTH button on your controller to do it at anytime, and you should get used to how it works... When you get your signal back you can cancel the return home and continue to fly |
