Geebax
Prop balance does not affect flight too much, it is mostly in order to eliminate the jello effect when shooting video.
The props from DJI arrive usually balanced OK, but some may not be, so it is worthwhile buying a DuBro prop balancer, plus the ccorrect balancing rod for your aircraft type. The procedure for using the balancer is well covered, both on here if you do a search or on Youtube.
As to how often you balance them, usually you check all new props and balance if necessary. After that, you do not need to touch them unless they get a nick in them, in which case you should replace them anyway.
