Z3 shaky footage?
770 5 2016-8-20
Burlingtonfilms
Flight distance : 61831 ft
I've seen some Z3 footage online and some of it looks shaky when zoomed in?  Is this the camera or maybe something else?
Also does the Z3 require the Inspire v2?
2016-8-20
tylerstanley
No you can use a V1. I upgraded to the V2 gimbal plate though.
On another Z3 issue, I can't swap between ISO and shutter with the remote wheel like I could with the X3 in manual mode. Am I missing something?
2016-8-20
DJI-Jamie
Flight distance : 112405 ft
Some movement can be present when the camera is zoomed in, but it should not be excessive. Could you happen to provide a sample?
2016-8-21
DJI-Jamie
tylerstanley Posted at 2016-8-21 09:49
On another Z3 issue, I can't swap be ...
To clarify, you only referring to the RC controls but the app control is present. Is that notion correct?
2016-8-21
AnzacJack
Flight distance : 3501650 ft
Im more concerned abvout the excessive shake when pointing straight down (not zoomed) and the horrible horrible lag that makes this new camera a very expensive lemon
2016-8-22
DJI-Jamie
AnzacJack Posted at 2016-8-23 14:16
Im more concerned abvout the excessive shake when pointing straight down (not zoomed) and the horrib ...
Could you provide a short sample of the issue?
2016-8-23
