Hansogren 9
Flight distance : 3499127 ft
Not sure if this post/thread is still being checked in on, but I've got a new scenario to throw in. I've got a P4 that has been giving me "NA" readings for VPS height; either that or it will say "0.3ft" or "1ft". The error occurred whenever I went into a hover, no matter the height (2 feet, 20 feet, 200 feet, all would say "NA" or something less than 1 foot). I tried recalibrating the downward facing vision cameras using DJI's Assistant program, and noticed that my camera gimbal was showing up on the downward facing cameras. While holding the P4 off the ground, I could get it it to give me accurate height readings if I pushed the camera gimbal forward a quarter of an inch. I thought that this must be the problem, but after fiddling with the gimbal position and the angle of the VPS camera sensors inside the body of the P4, no luck. So then I tried covering the ultrasonic sensors with a piece of tape, and lo and behold I had VPS accuracy again, anywhere from roughly 4 feet off the ground and higher (I haven't flown it around yet, but from holding and lifting the P4 off the ground at various heights, the VPS would accurately display my "hover" height). I now believe the VPS cameras were working fine all along, but it was my ultrasonic sensors that were getting confused by the camera gimbal in front of them. What doesn't make any sense to me is that they had been working correctly before, and I've had no crashes or hard landings, and yet something changed in positioning to cause this error.
Has anyone else experienced issues of getting either a VPS reading of "NA" or something lower than 1 foot, no matter the actual height of the drone? Does anyone have any ideas on how to correct a malfunction involving just the ultrasonic sensors? I've looked carefully at them and cannot see any obstruction or debris around the ultrasonic sensors, so I'm unsure as to why it suddenly began giving consistently false height information. |
