Kneepuck
Flight distance : 275105 ft
The smart rth will try to determine how much battery life is required to rth from its location and update the battery information bar based on that. It can be misleading because if you fly out with the wind behind you, you will be covering ground very quickly. The drone will show a green line on the battery info bar, and you may continue flying along until it displays a warning saying automatic rth is initiated. But, because you will now have a headwind for the return trip, you will not make it home. The drone will wind up landing wherever it is when voltage gets critically low. On the other hand, if you fly into the wind on the outbound leg, the drone will see the distance you covered vs remaining battery life and decide it needs to rth. This you can safely override, because you, as the human who is smarter than the drone, know you will have a tailwind on the return flight, so will cover the same amount of ground much more quickly, and in fact will probably land at the home point with plenty of battery life still remaining.
Hope this helps.
