DJI Natalia
Hello Sir. For this Error code, please try to restart the aircraft for several times firstly, and uninstall the APP then install it again. If still the same case, please help me confirm the following items, thank you in advance.
1. What is the mobile device you are using? Have you tried another one which is compatible with the drone?
2. Please connect your PC to the aircraft and copy the original photos from the SD card to your PC, then check whether it is fine.
3. What is the firmware version of the aircraft and the APP? Please upgrade them to the latest. |
