fansd976cade
Flight distance : 202953 ft
Geebax Posted at 2016-9-9 17:37
As AG0N-Garry says, there is a micro-SD card in the drone, in fact two of them. One stores your pictures, photos and logs, the other stores flight logs and is fixed inside the aircraft. You cannot delete the files on that drive, and as Gary says, it most likely has a file scavenging process to mage the storage.
The files CAN be deleted simply by connecting aircraft to PC. You also have to connect the controller to your phone first to enter flight data mode, files will show on PC screen, then delete them. To answer other questions, older files are automatically overwritten when aircraft SC card is full. |
