hi, reading all the stuff on potential or occurred mishaps. Are there any simple affordable devices that can give you some idea that you might be standing above a magnetic black hole. If a normal compass works, should the P4 compass also work?
I also tried several apps and found one that works. Tested it at power transformer station near a park. Also amazed at how much it reacted to my truck. I have an android phone I use it on. Keep minimum apps on iPad.
radiomike Posted at 2016-9-10 12:36
I also tried several apps and found one that works. Tested it at power transformer station near a pa ...
The trouble with those apps is that they use the compass that is built into the phone, and the aircraft may not react in the same way. Ken's method uses the compass in the aircraft, which is far more relevant.
