Terry G
Flight distance : 1773327 ft
It finally happened. 230+flights and I finally had a hard landing. Inspire was going about a walking speed and brushed a small tree and dropped about 4 feet and ended up on its back. 2 of the 4 rubber gimbal mounts had come loose and no other visible damage. Powered everything down, reconnected the rubber mounts and fired everything back up. Camera didnt respond and the app said "gimbal disconnected". Powered everything down and removed the camera and the gimbal to see if I could see anything obvious but I didnt. Made sure what connections I could see were connected wthout dissasembling more of the craft. Fired everything back up and the camera remained "limp" and the app said "gimbal disconnected" Any suggestions where I should look to fix the problem?
