MD_Icarus
I did something similar too using the cardboard case from a keyboard. I created an L type sun shade and I then used black tape all over it. And I placed a rod to keep the K1 from falling out when I tilt the RC. It works, the tablet wont fall off even if I turn it upside down!
I will recommend to DJI to consider placing a similar edge on the top of the RC bracket, similar to the one they have in the middle, which folds out. Wen the tablet is held by the 2 end pieces, it can fall right off.
BTW: Why is the DJI Go app version 2.9.1 instead of 2.9.2?
Also, the Android version is a bit more "touchy" when it comes to connecting to the P4. I have realized that I have to turn the K1 first, then the RC, I get a message to run the DJI GO, and then it defaults to Inspire. Once I turn the P4 on, it goes to P3A and then finally it recognizes the P4. Ths process is so much more refined on IOS. It always remembers the last connection and it starts with a P4. Also, if I make an android settings change, while running DJI GO app, I get disconnected! This scares me a bit.
I have not yet installed Litchi because I am not sure I will use the K1; but I assume I can use Litchi and DJI GO on Android? I guess DJI Go asks me every time that it is the default app, as soon as I turn the RC on, but I have not saved it as the default. Will Litchi do the same? On IOS I do not get this pop up, to choose a default app. I can turn one off and start the other one.
Sun Shiield (Home Made)
