brunobaptista55
Flight distance : 1369839 ft
Brazil
Hello,
I´ve searched this and other forums, as well as the manuals and could not come up with a definitive understanding.
Let´s say that I have my max height set to 120m, and my RTH height set to 60m. What happens if during a RTH (with Obstacle Avoidance turned on) the aircraft encounters an obstacle say 90m high? I expect it to climb to 95m (5m above the obstacle as in the manual) and as long as it does not hit the 120m maximum height it will continue to RTH.
So the maximum height of an obstacle that it would avoid is 5 meters less than the maximum height set (in this case 120m maximum minus 5m clearence thus 115m).
In the situation that it encounters an large obstacle (such as a building) that it could not clear vertically within the max height set, it would hover, and eventually auto-land at the critical battery level.
Is this the way it works?
Thanks.
