Delete the link to the Master RC and then Re link it again, see if it goes away . Also just keep in mind that the video comes directly from the AC in contrast all control is done through the Master RC Via the link between the Master and Slave , So Make sure the Slave RC Antennas are not crossed and in general pointing towards the Aircraft.
Do it like this :
Erase the master RC from the memory of the Slave (Start fresh ) then do the procedure For Video Problem Below then do the "Find " the Master RC procedure. This should clear up any problems if it is software and not hardware failurre.
For Video problem refresh the video link
Press the C1 + C2 + Trigger (photo) buttons and keep them pressed and TURN OFF the controller.
By still keeping pressed the C1 + C2 + Trigger (photo) buttons TURN ON the controller.
Good luck
donnie
