AyrshireUAV
Flight distance : 957297 ft
I sent my X5 into DJI last week via UPS and I'm still waiting on it even tracking on the UPS website. I have exactly the same damage as you have. Mine occurred after using it on my Osmo Pro. The Osmo powered down unexpexdedly and the X5 under its own weight went from pointing horizontally to vertically. This action caused the damage to the same area as yours. The area that is broken appears to be extremely thin and not made from high grade materials that you would expect from "professional grade" equipment. Given when used as part of the Osmo Pro the camera and gimbal is upside down, you would expect the part holding the weight to be sturdy enough to hold everything together. I wasnt outside when this happened. I wasnt up a hill, on a moor, or filming a chase scene. I was sitting in my living room, I had the Osmo in its holder and I was physically holding it when it happened. Like you, I take care of my equipment. I have 6 different HPRC wheeled cases for my Inspire 1 Pro, Phantom 4 and my Osmo. I have 3 Manfrotto backpacks, and numerous bespoke Peli cases. I take no chances. My X5 came from the first batch when originally released back in 2015. My X5 broke 366 days after I took delivery of it. You couldn't make it up! I have taken 30 images of the damage, the X5 itself and of my X5 case before sending it in. I have images and records of all serial numbers and codes. I really hope my experience is better than yours.
***Update***. I now have a brand new X5 courtesy of DJI. My broken one was replaced free of charge. Once it appeared on the tracking system the process was pretty straight forward. I received a few updates and had it back in my hands about a week later. Cant fault their RMA one bit in this case. First Class actually.
