What is "Litchi"
940 4 2016-9-28
coolure
Flight distance : 15049 ft
United Arab Emirates
What is Litchi ! is it recommend by DJI to use with P4?
2016-9-28
Jkeller84
Flight distance : 396955 ft
3rd party app. If you have a crash and DJI determines that a 3rd party app caused it, no warranty.
2016-9-28
a_aviator
Litchi is more extended version of DJI Go app. It has some advantages - for instance you can use VR glasses which will block sunlight when you are flying. Litchi and other Apps ( Dream Flights http://www.dreamflights.pro/fly.html) are very cool if you want to try FPV. But, yes, be carefull - there is no warranty if the App will cause crash or other problem.
2016-9-28
DJI-Ken
Flight distance : 1515312 ft
Using it and having a crash and losing the aircraft may be a warranty issue.
If the aircraft is sent in and determined a aircraft malfunction happened and had nothing to do with the app then it may be a warranty repair as the flight data recorder could be analyzed verses a lost aircraft and DJI flight records wouldn't register.
2016-9-28
coolure
Thanks for the replies guys. If there is no warranty i will not use that 3rd party apps.
2016-9-28
