Mabou2
Flight distance : 811257 ft
Hi again Bob, Understood. I'm not arguing with you at all, nor am I being disrespectful. I'm only trying to help. (and I feel bad for you losing your drone). So, with all due respect.... From my perspective, you were using a piece of equipment (gimbal guard) that DJI warned us not to use, for the exact reasons that you expressed caused your crash. It probably doesn't matter that your bird was fine one day and not the next. It probably doesn't matter that the start of the flight checked out. (this could be somewhat akin to a driver saying that they always text safely when driving and it has never caused a crash so they are angry at the car company when they crashed their car). What DOES matter is that you crashed while using an unauthorized piece of equipment, and you crashed under the exact parameters of expected erratic behavior when using said piece of unauthorized equipment. Unless your gimbal guard was bolted in place, and unless you had some way to statistically know that this particular guard had absolutely no effect on the VPS, this is pilot error. It could be that the simple vibration of multiple flights (or a simple bump when packing things away) eventually moved that guard a few millimeters forward. It could be that the guard was always a borderline problem but the VPS was able to overcome it on most of your flights. It could be that your VPS sensors acquired a small amount of dust (that would normally not be a big problem) but in this case the sensors were now more affected by the guard being in place. I (clearly) don't know exactly what happened to cause your crash, but in armchair quarterback mode, you were flying with a piece of equipment that is known to cause a particular kind of problem, and you had that particular kind of problem. DJI doesn't always have the best tech support responses, but that doesn't mean their final conclusion was wrong. You escalated the issue with DJI, tech support took a deeper look at the parameters of the crash, and came to a final conclusion. This doesn't mean they changed their mind, it means they looked deeper into the problem (as you requested) and based on telemetry coupled with the knowledge that you had a gimbal guard installed, concluded logically that the gimbal guard instigated the issue. |
