ge0se
Flight distance : 3184721 ft
I have a workaround for this but it's not too elegant. There's actually a bigger problem with proxies, they're all several frames shorter then the DNG sequence which is a big pain.
What I do to use MOV files as proxies is drag all MOV files onto one video track, then make another track and drag all DNG video sequences into newly created video track so starting point matches the track with MOV files. From here I can group these two tracks, disable RAW track and edit them as a single unit while having real-time playback (which isn't possible with raw 4K files). When I need to grade or manipulate RAW video I disable the proxy track (with H264 footage) and enable RAW track and vice versa.
This is where the different length of the files becomes a huge pain as I have to manually allign each H264 clip with RAW clip before editing can be done. Wanted to start a thread on it many times but got carried away.
DJI, please fix it, it's a huge workflow killer. |
