ched
South Korea
Hi there,
For further updates I would like to setup my lightbridge with multi-ground station.
- First use would be to have the FPV feedback for the pilot independent of the camerawork (I still find sad that the USB connection of the LB cannot at least transfer an SD signal while the HDMI HD feedback is used).
- Second would be having several ground stations around an event to secure a live HD feedback from the air.
Now everything seems to be made easy to do so, except that the only way I see to get extra ground stations is to get a full LB set. I can understand that the Air part is much cheaper than the ground station, but I'm still fairly reticent at having so many spare air links.
Is there any way to get a simple ground station, alone?
Thanks for your answer, and otherwise great product!
ChEd
