prejudice when they bore the imu I see this yellow warning gimbal roll Reached end point as you can see in the photo, I contacted support netherlands but they told me, I state that the drone was just received after two assistances
Hi, have you crashed the aircraft before?
And please make sure you have remove the sponge on the gimbal.
If the error persists, I'd suggest you to send it in for further evaluation.
I have sent the drone for two times in a row because the videos were being moved and accurately I sent the drone August 18th and September 10th just received and was sent back because he had the same defect so I could not use even ten times for your lack
I try to explain it better, my drone was sent into care twice because the videos were being moved, so the second time they gave me the drone again but with this defect
Have you tried to do the gimbal calibration?
Please try to do the gimbal calibration first and then do the IMU calibration.
When you power up the aircraft, will the gimbal calibrate automatically?
I did as you told me before calibration gimbal then IMU but this and the result as seen in the video, also support netherlands told me not 'a problem{:4_154:}
and be told this and ugly, because the facebook page (DJI Phantom Italy) to anyone so happens I'm annoyed Dutch support
I did as you told me before calibration gimbal then IMU but this and the result as seen in the video, also support netherlands told me not 'a problem {:4_154:}
I'm sorry you are experiencing difficulties.
It's probably a hardware issue.It's better to send it in for further evaluation.
Please contact with our tech support via support.eu@dji.com.
