labroides
Flight distance : 9991457 ft
If you were on a boat and nearby, there should have been a clear line of sight to the Phantom where the signal was lost which was only 30 metres inland from the beach at 6.71224864S 39.23360288E .. See the picture.
I'm a little puzzled why you were getting a few short breaks in the video signal but that probably doesn't matter.
The big issue is that your Phantom thought that it was 3.5 kilometres from home and in an RTH situation, that is where it would have tried to go to.
However, there is no sign of RTH until 19:03 at 25% battery when you regained signal after a 9 second lapse. The Phantom starts returning toward the recorded home point.
it only travels 145 metres north before the flight record ends with the Phantom at 100 feet altitude.
There's no record of any crash ... the record just stops.
It appears that RTH as cancelled 1 second before the flight record stops.
Battery level is 23% and 14.6 volts - not enough to go back to the launch point.
It's uncertain what happens after this point.
If it was still in RTH it would have continued north until 10% and landed but RTH was cancelled.
There's no indication of any problem due to a military base.
When you are a long way from home on a moving boat, you must reset the Phantom's home point so the Phantom doesn't try to go all the way back.
