Favor Please: Need Dimensions For Mavic Pro (UPDATED)
12Next >
34437 72 2016-10-18
johnlega
I'm looking at making some templates for stickers (while we wait) and need some basic dimensions for the Mavic. I know some of you have it (testers) or perhaps even DJI-Ken can help with filling these in (see attached JPG).
Thanks so much. If/when I get it done - I'll be happy to share.
Thanks all,
John
UPDATE: I updated the graphic with dimensoins from DJI_Ken (Thanks!). I traced it in Autocad best I could. The picture had some perspective distrotion so it may not be exact but if Ken's dimensions are pretty close - you could scale it up in certain areas to conform to the dimensions. The only dimensions in the DWG that is dead on is 275mm (rotor to rotor horizointally). If anyone has updated info - please let me know and I will update it.
Mavic Pro Plan View.zip
32.14 KB, Down times: 100
AutoCAD DWG
2016-10-18
johnlega
DJI-Ken - can you help me with this?
2016-10-18
DJI-Ken
Flight distance : 1515312 ft
johnlega@gmail. Posted at 2016-10-19 02:33
I will see if something can be done to help you.
2016-10-18
johnlega
That would be great. Ideally a 3D model (only outside shell) would be great.. just need to get some accurate outer areas to maybe makes some stickers... just to pass the time....
Thanks Ken.
John
2016-10-18
DJI-Ken
johnlega@gmail. Posted at 2016-10-19 03:09
That would be great. Ideally a 3D model (only outside shell) would be great.. just need to get some  ...
I may be a few days.
2016-10-18
johnlega
No problem... you mean sometime in November? LOL... sorry - too soon?
Thanks man.
John
2016-10-18
Linsenfest
Flight distance : 199475 ft
Could need it too
I´m a graphic designer so i could design my own mavic
2016-10-18
DJI-Ken
johnlega@gmail. Posted at 2016-10-19 03:28
Thanks man.
Ha Ha, I will be in next week and can do it.
But to assist you I'm trying to get someone there to do it.
2016-10-18
Travis199
Flight distance : 144039 ft
Can i grab a copy of these too please, would be cool to make up some skins n the old roland
2016-10-18
johnlega
DJI-Ken Posted at 2016-10-18 14:33
But to assist you I'm trying to get someone there to  ...
Thanks Ken - that would be great... seems we have another few weeks to prepare for this bad boy.....
John
2016-10-18
johnlega
Could you tell me what the distance is between center of propellers in both directions? Dimensions "F" and "G" in picture. That will get me in the ball park until I have more info.
Thank you,
John
2016-10-19
Maverikster
Flight distance : 24672 ft
johnlega@gmail. Posted at 2016-10-19 16:55
Could you tell me what the distance is between center of propellers in both directions? Dimensions " ...
Did you notice the bottom props are closer to each other than the top ones? So you might need another dimension (F is not same distance for bottom props)
2016-10-19
phatee
Flight distance : 36165 ft
this is the only sticker i'm going to make for my mavic.
2016-10-19
DJI-Ken
johnlega@gmail. Posted at 2016-10-19 03:59
Thanks Ken - that would be great... seems we have another few weeks to prepare for this bad boy... ...
I'll try to have someone get some measurements, if not than I will get some when I'm in the office next week.
2016-10-19
dana5
Flight distance : 14354 ft
phatee Posted at 2016-10-19 23:37
I like it!
I had "angry eyes" on my P4 (which I no longer own).
I thought of googly eyes on top, or, perhaps using hot glue to attach a lego pilot to the top!
Just kidding... I have no plans to put anything on mine, except for the required FAA number, and a DynoTag on both the drone and the controller. I also put a number, and a date, on every battery, so I know which is which, and how old each one is.
Also, an NFC tag on the bottom of the controller is nice. I use an app called "Trigger", to set the tag to:
Start DJI GO
Set brightness to highest level
Lock display in landscape
Turn on DND (forward to voice mail)
Set volume at max
Trigger is free, and NFC stickers are cheap, at under $1 each, and getting your phone ready for flying is as simple as just scanning the tag.
2016-10-19
phatee
dana5 Posted at 2016-10-19 12:35
I like it!
like whoa. i'm assuming you'll be using an android device because i don't think iOS has that functionality with NFC chips.
2016-10-19
dana5
Yes. I will continue to usr android. I usrd to have iphones, but seitched to android, and think it is far more poerwful, and less restrictive.
2016-10-19
dana5
I see some of the dimensions on the DJI site. But I think these numbers need to come from DJI or one of the lucky few that have one.
2016-10-19
FlashGJ
Flight distance : 293379 ft
Not sure if you already have these, but I got this off of a review made by a couple of Chinese guys, so I do not know how accurate the information is. They stated that the dimensions when folded are: H83mm x W83mm x L198mm. So your B dimension would be 83mm and your K dimension would be 198mm.
2016-10-20
dana5
FlashGJ Posted at 2016-10-20 10:22
Not sure if you already have these, but I got this off of a review made by a couple of Chinese guys, ...
Also, even though you do not have the dimension listed on your diagram, the diagonal from the prop to prop is 335mm. This would be, for example, from the front right motor, to the rear left motor. However, I am not clear if that is outer dimension or from motor axis to motor axis. I assume the latter.
I assume you are wanting these dimensions for a foam cutout, and want it to be exact?
2016-10-20
johnlega
dana5 Posted at 2016-10-20 12:09
Also, even though you do not have the dimension listed on your diagram, the diagonal from the prop ...
Thank you. I wanted to make some stickers and I need the proper areas of the surface so I can cut them out accurately. I guess I don't need it down to the millimeter but being a designer - I like to be precise... LOL.
Thanks,
John
2016-10-24
Lepus
Just use a permanent market if that is what you are looking for.
2016-10-24
DJI-Ken
Getting SOME of your dimensions right now.
2016-10-24
pythagoras183
Adding some more templates.
2016-10-24
DJI-Ken
These are in mm and rough as I used a ruler:
A 45
B 83
C 28
D 105
E 66
F 275
G 220
H 10
I -
J 10
K 200
L 45
M 72
N 78
O -
P 88
Q 210
R 85
2016-10-24
DJI-Ken
pythagoras183 Posted at 2016-10-25 01:37
S 114
T 31
U 28
V 26
Again these are rough.
2016-10-24
pythagoras183
Thanks. Can you get a rough L x W x H for the collapsed controller?
The controller sticks are removable, right? If so, you don't need to include them in the height.
2016-10-24
DJI-Ken
pythagoras183 Posted at 2016-10-25 01:48
The controller sticks are remo ...
Yes, sticks pop out and can be stored in the holder.
L 145
W 77
H 35
Roughly
2016-10-24
pythagoras183
Hmmm, I think the 28mm battery width (U) might be wrong. The width of the drone (B/R/M) is around 83mm, which is more than double that.
It should be closer to 60mm, I believe.
2016-10-24
DJI-Ken
And the AC adapter:
L 115
W 48
H 28
2016-10-24
allen.rn
Flight distance : 21827 ft
It would be cool if johnlega would repost the pics with the dimensions filled in.
2016-10-24
Crusader 901
Many thanks to johnlega and pythagoras183, you took the words right out of my mouth.
I have been looking everywhere online for some more dimensions on the Mavic and controller to make my own sticker set too!
Now i can give my Gerber Edge FX and the Envision some food, and it will kill some waiting time on the "fly more combo" in the mean time
And of course big thanks to DJI-Ken for the dimensions!
2016-10-24
johnlega
allen.rn Posted at 2016-10-24 13:18
I will... hang tight.
2016-10-24
Crusader 901
Thanks in advance!
2016-10-24
johnlega
Graphic updated and provided (traced) AutoCAD file (DWG). Hope this helps.
2016-10-24
DJI-Ken
Crusader 901 Posted at 2016-10-25 02:22
I have been lo ...
Your welcome, but remember I did these quickly and with a ruler.
2016-10-24
johnlega
DJI-Ken Posted at 2016-10-24 14:17
Ken,
We need you to purchase a caliper and get within .05mm please.....LOL.
Hey - any chance of getting a 3D model of just the outside shell... no proprietary info?
2016-10-24
johnlega
Ken - sorry - I forgot another dimensions (in case it's not the same). What is the distance (center to center) between the front rotors? Is it 275 as well? Could you also verify one more time the over  length (shown as 200mm currently).
Thanks bud.
Regards,
John
2016-10-24
pythagoras183
I'm probably going to try tracing these with a pencil to get a snug foam fit. There are some hard to measure angles.
2016-10-24
Crusader 901
DJI-Ken Posted at 2016-10-24 20:17
Noted, but still thanks for the first ruff dimensions!
2016-10-24
12Next >
