Dear All,
I have a customer that has purchased a DJI Phantom 2 Vision+ V3 from us recently. The customer is reporting an inaccurate altitude reading of + 6 Meters (19.6Ft) at ground level or take off. Sometimes the unit will read a 0 Meter level at take off but further into the flight will read at a positive reading when on the ground.
Advanced calibrations have been preformed on the unit. The unit also has a 7+ satellites locked in with a green flash pattern (good for take off).
From what I can tell the unit has a barometric altimeter however there is no way to enter pressure therefore temperature can have a big effect on the readout. The Return to home descends at a constant rate so an inaccurate reading for altitude should not hinder or damage the unit if it's on a RTH.
Does anyone have any experience with the barometric altimeter in the phantom 2 series that may know of a fix or solution to calibrate or reset the readout?
Thankyou,
Zack |
