Swhitch the HDMI Module from Phantom 3 to Phantom4
928 7 2016-10-26
Morfeus
Flight distance : 4173091 ft
Hallo guy...
I will ask you a little question...
I've got a Phantom 3 Professional and a Phantom 4.
The HDMI module is on Phantom 3's Radio.
Could I switch it from here to Phantom 4 RC and each other?
Is it complicated?
Thank you...
2016-10-26
Aardvark
Flight distance : 384432 ft
Why not just use controller with HDMI module to control both (or when needed) ?
It would be a two minute job to re-link to each aircraft.
That would be a simpler solution unless you were only intending using the HDMI on the P4.
2016-10-26
Morfeus
Aardvark Posted at 2016-10-26 16:22
It would be a two m ...
I didnt't thought to that... because thought to sell the phantom 3...
But if you link as you said how could run the sport mode on P4?...
Switches on Radios are different...
2016-10-26
Aardvark
Morfeus Posted at 2016-10-26 15:26
But if you link as you said  ...
Different labels perhaps.
I'm sure there are a couple of regulars on the Forum working like this. They might be better qualified to give a reply as I haven't tried this myself.
2016-10-26
Morfeus
Aardvark Posted at 2016-10-26 16:41
I'm sure there are a couple of regulars on the Forum working like this. ...
thank you Aadvark
2016-10-26
digdat0
Flight distance : 11896378 ft
Moving the HDMI board over is SUPER easy.  But, Aardvark is right, the transmitters are interchangable. On the "switch" p4 = "S" and p3 = "A" .. but it does the same thing.
Basically, it requires 4 screws on the back, remove the plastic piece and then 3 screws to undue the board. You have to unclip 3 ribbons, 2 are kinda small so be careful. Pull it out, put the new board in and carefully put the ribbons back in place,t hen the plastic cover. It was really one of the easiest mods I've done on the phantom, adn the video above is pretty good.
2016-10-26
Hi Morfeus, you could folllow the video tutorial provided by digdat0.
2016-10-26
opendoor499
Strange thing: i have a phantom 3 advanced, and have installed the HDMI module and a DBS antenna for better range, then i bought a phantom 4 and used my phantom 3 advanced controller for the antenna mod. which all works fine. I always though as far as range goes the phantom 3 a was better but after the new controller updates i found that the phantom 4 had MUCH better range than my Phantom 3 advanced.
2016-10-26
