Samsung Galaxy Tab A connection
516 5 2016-10-26
leigh.spargur
Been flying my p4 with my Samsung phone for months. Just got a Galaxy Tab A and cannot get it to connect.  I have followed all the setup instructions.  Nothing seems to work. Any ideas?
2016-10-26
ilav
Flight distance : 153179 ft
Tab a setting: development options set usb  configuration to mtp, ii
works for me.
2016-10-26
Please try ilav's advice and make sure you have USB Debugging enabled.
2016-10-26
Cetaman
Flight distance : 2494390 ft
Aloha leigh,
     If you do not know how to enable Developer Options, this is how;
Go to the Settings icon
Open Settings> About> Software Information> More.
Then tap “Build number” seven times to enable Developer options. ...
Go back to Settings menu and now you'll be able to see “Developer options” there.
Tap it and turn on "Connect as a Media Device", "USB Debugging" and other options you may need from the menu.
     Hope this helps!
Aloha and Drone On!
2016-10-27
mmarkoe
Flight distance : 15135 ft
I have a Tab a.The easiest way to get the Galaxy Tab a to connect is to first start your remote controller, then start the aircraft. Next connect the cable to your Galaxy Tab a and boot up the Galaxy Tab a. You will then be able to connect without a problem.
2016-10-27
DJI-Jamie
Flight distance : 112405 ft
Try ilcv and mmarkoe's advice and let us know if you have any issues.
2016-10-27
