hallmark007
Flight distance : 9827923 ft
There is a significant difference, if your lights fail you won't drop out of the sky, if as op said he was panicked in emergency he does not no what to do, first advice to give him is to prepare before he goes out flying, and in my opinion if you don't your asking for trouble, so my first piece of advice would always be make sure your battery is fully charged, yes his problem is most likely bad calibration IMU , Of which he said he had done and done again I suspect in the park, now if he's doing cal IMU in the park that's crazy, so first things first prepare properly before flying,
I think if you go on to P4 forum you will see many instances where battery suddenly drops from 80% to almost nothing and landing just takes place where battery runs out, some have put up logs, I suspect others just didn't check before take off, I think if you look at latest crash here on forum , you will see the first thing pilot says I had 40% battery left, not a coincidence he said this, he's letting you know that at least he was prepared for his flight. |
