DJI GO - Supported Xiaomi phones for Mavic
12Next >
37828 60 2016-11-2
N0N4M3pl
Flight distance : 48330 ft
Poland
Anybody use DJI GO with Xiaomi phone? I planning to buy new phone for my Mavic and i choose this 3 models:
  • Xiaomi Mi Max 3GB/32GB
  • Xiaomi Redmi Pro 3GB/32GB
  • Samsung s6 - but this is twice expensive
Do You have some experience with this phones and DJI GO?
2016-11-2
Hello, Samsung s6 is in our DJI recommended device list.
And Mi 3 is in our recommended list as well.
For your reference.
2016-11-2
ENG101
Flight distance : 19642 ft
New Zealand
DJI Mindy Posted at 2016-11-3 15:49
And Mi 3 is in our recommended list as wel ...
Hi. I can't find anywhere that sells the Mi 3. The current model is the Mi5. Is that supported?
2016-11-11
DJI-Ken
Flight distance : 1515312 ft
ENG101 Posted at 2016-11-12 11:46
These are the devices that are supported, others may or may not work or partially work.
iOS Version v3.0.2.
Requires iOS 8.0 or later. Compatible with iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus,iPod touch 6,iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s and iPhone 6s Plus.
Android Version v3.0.1.
Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
*Support for additional Android devices available as testing and development continues.
2016-11-11
fansd2e22cbc
The Mi5 should work for sure, its a pretty high end phone. I have a mi5s plus on order so I can check that when it arrives.
The Max is more limited in processing power, RAM but a nice big screen and cheap, would be nice to know if that works.
2016-11-11
DJI-Thor
Flight distance : 13602 ft
Yes, they all should work.
The Max/ Redmi Note Pro  uses  650/652 CPU, which is on par with the previous 810.
They are good budget choice
2016-11-12
fansdc0b091d
Flight distance : 1210525 ft
Mi Max 64GB not work
Plug in USB, can't detect device
I use Mi Note4g before, work fine
2016-11-12
cegio
Flight distance : 671257 ft
Hi, I`m using xiaomi mi5s Plus and do not have any problem with p3pro ,osmo and inspire 1. But  have the same problem that samsung with android 6.0.1 , I can not have installed dji go and litchi in the same phone.
2016-11-13
patman89
Flight distance : 288327 ft
Just ordered the Xiaomi Redmi Note 2 - hope it works fine with the Mavic Pro
2016-11-16
trox
What about Samsung S7 and S7 EDGE?
2016-11-16
hedfan
Flight distance : 21470 ft
trox Posted at 2016-11-16 11:48
And the iphone 7!
2016-11-16
Tommy Silaban
Flight distance : 974364 ft
Indonesia
my mi max 2/32g dont work with dji go app , any solution to fix that?
2016-11-28
ferranclotet
All this stuff with the mavic it's a joke, Xiaomi mi5 doesn't work!!!!
2016-11-30
Reinheart
Flight distance : 353048 ft
Indonesia
I just bought Xiaomi Redmi Note 4 for my Mavic, DJI go succesfully Installed but it cant run?? Why?? Pls help.... Thank you.
2016-12-9
HardCore
Singapore
I tried the following with DJI Go and Go 4:
Redmi Note 1 - Failed
Redmi Note 2 - OK
Mi Max 32G - Failed
Mi Pad v1 - OK
It's strange why some andriod devices would not work...
2016-12-19
fans805cfeea
Flight distance : 259226 ft
Russia
All is very simple! I'have the same problem too with Phantom 4/Pro and Mavic with a Xiaomi mi Max 16 and Redmi Note 4 - both with 6.0.1. the solution is simple. 1 - you need to enable "testers mode" - in the "about phone" - you need to tap 10 times on a MIUI version, after it you need to eneble "USB debugging". DJI Go And Litchi can not work in the in one workspace. You need to ENABLE second Workspace an to install DJI Go In First and Litchi In second. or vice versa. How convenient. and all will be well. Tested on Mavic and P4 and P4P with Mi Max 16 and RedMi Note 4
2016-12-22
18Trotter
fans805cfeea Posted at 2016-12-22 11:27
Hi,
First of all I would like to say I'm new to the forum and greet everybody. Secondly, I'm grateful for everything I could read here from all the contributors in various threads, since I'm sure it will have a beneficial effect in real life experiences with a drone.
Now, I would like to say I do not own the drone yet, but am on the verge of buying the Mavic. I will also need a new phone for the RC and thought about Xiaomi Redmi Note 4. Therefore, it is to me of utmost importance to know beforehand whether this phone will operate smoothly with the Mavic and DJI GO. I read your post with great interest and hope that I could be successful with the Redmi Note 4 although prior to that I kept hearing it was rather a no-go. Still, I would like to ask you to confirm that based on your experiences the phone and the Mavic work together with no problems in various scenarios / modes of operation. If there were any issues please report in details what kind of stuff it was. What are the strong and weak points of this pair ?
thanks in advance and regards
Greg
2016-12-23
molyvos
Flight distance : 74610 ft
Greece
If it's any help, I just connected to my Mavic  successfully using DJI Go with a Xiaomi Mi 4c 16GB. Everything seemed to work OK.
2017-1-25
fans6d131b63
Belarus
For a long time could not find a solution until i found it himself: To  Xaomi Mi Max connected to the RC Mavic without problems - all of you need  to do is disable the USB debugging mode ;) Good luck to all!
Turn off Debug on USB mode.
2017-1-27
Format0
Flight distance : 211371 ft
As for my Redmi note 4, DJI go and DJI go 4 or Litch or even dronepan, cannot be installed simultaneously, if there is more than 1 app installed, any of them will not work.......so I can only use 1.
2017-2-8
fansc725fe25
the xioami note 4 does not work with mavic it did with my P4 but only if you un installed litchi or visa versa go app, anyone know how to fix this?
2017-2-10
fansc725fe25
fans6d131b63 Posted at 2017-1-27 12:56
thanks
where do I turn this of in settings?
2017-2-10
fansc725fe25
yup Ive become a developer and got in but ut was set to off still wont connect....
2017-2-10
fansc725fe25
fans805cfeea Posted at 2016-12-22 02:27
excellent worked for me someone above sais to turn usb debugging off but on what you said it worked..I also desintalled gopro apps I had and other flight apps did a re start and it worked now I can enjoy 1080p in my goggles
2017-2-10
fans07509e3c
Flight distance : 101978 ft
Strange cause my mi max 32g work without any issue
2017-3-8
FLwaverunner
I've been using iPhone 7 for 3 months now. No prob, works great!
2017-3-8
KevDrones
Flight distance : 475522 ft
Samsung S7 Works great, also use my Iphone 7 Plus, but S6 works good also probably.
2017-3-8
nickzavi
Flight distance : 137257 ft
Greece
redmi note 4 great experience with my phantom 4 and dji go!! everything smooth and no lag!!!!!!!!!!!
i have the global version 8.1.6.0
2017-3-13
Flyboyz
Flight distance : 142615 ft
Singapore
Hi, saw that it support xiao mi  Mi Pad, any one know if it support  the latest MI Pad 2?
2017-3-13
Javier5
Flight distance : 68064 ft
i think use second Space in Miui8 with 6.0.1 is partial solution,
if i need in same mobile Dji Go, Litchi and Dronedeploy not possible.
Only possible 1 app in fist space and other in second space.
Ciusly other app: Altizure
it works perfect at same space with dji go.
Litchi  and Drone Deploy are poorly code?
FIx please DJi, Litchi, Dronedeploy or to whom it may concern
2017-4-4
fansd404fbb7
Flight distance : 3392 ft
https://forum.dji.com/member.php ... 3Dyes&type=post
2017-4-21
fansd404fbb7
Hi everybody ! Just to say that after multiples tries, my new Xiaomi MI 4S did not work even with USB debug or removing apps.
But, at the end, putting DJI GO in a second space, it was working perfectly without crashes and lags.
2017-4-21
fans1830f0b1
Flight distance : 2280459 ft
Czechia
My Red Note 4 will connect without a problem if the usb debugging is turned off, the application dji go but often fall and the phone restarts. If I decide to go in or go to the airplane mode, everything works properly. Litchi must be installed in the same space. Another problem is that when recording a sreen record there is a large latency of the transmitted image, up to 2 sec.
2017-5-8
fans1830f0b1
Czechia
Sorry, Litchi installed in second space
2017-5-8
fans1109ab43
Singapore
My Xiaomi Redmi 3S (on 6.0.1) works well with DJI Go (4.0.7) and my Mavic Pro (FW .600). So far so good.
2017-5-8
patman89
I am using a Xiaomi Redmi Note 2 without any problems!
MIUI 8 & DJI GO 4.0.5
One thing to mention:
DJI Go 4.0.6 and 4.0.7 do not work! But if you take a look at this forum and the many 1-Star app reviews you can see this might an overall issue at the moment. The last stable DJI Go App for Android was 4.0.5!
2017-5-8
fans06911f06
Portugal
Good afternoon, any solution to the mi5?
Bought the MI6 should arrive this week and I'm afraid that does not work, I could not even put mi5 to work with mavic
2017-5-30
fans1bb32db4
Flight distance : 64436 ft
Singapore
My Xiaomi Redmi Pro works, the version with dual rear camera lens.I struggled initially with the problem with the disconnected issue. After fumbling with it for an hour, I later learned that you will need to perform the following to get it  connected,
- Enable developer mode (google on how to do this)
- Once Developer mode enabled, turn on the following in the Developer options - USB Debugging , Install via USB, USB debugging (Security settings)
- Plug in the cable, you will see the phone in charging mode, change it to File Transfer mode <- This is a must do
You should see your phone connected to the RC.
2017-6-8
ddumaguin
Flight distance : 252884 ft
Philippines
I'm using a Xiaomi Mi6. I encountered a problem just now and I happen to come here looking for a solution.
I was flying for about 2 minutes when my remote and DJI 4 app disconnected with my Mavic when I was landing. I cannot control the drone with the remote control anymore and my Mavic is just there hovering 8 feet above me, i tried restarting the app but it won't connect anymore. Since the drone is not connected with the remote it slowly descended to land but I started to get scared coz it was also drifting away from me towards a pond. I chased the drone and thanks to my long reach and height I was able to catch it just before it went over the fence to land in the pond.
The remote battery level is at 91% and the Mavic battery is at 83%. I do not know what's the problem was wether it because of the app, or the type C cable that comes with the remote, or the new firmware. This is the first time that this has happen and I was flying my Mavic without any issues after the my update last week. I tried using the usb port below the remote but its not running the app when I turn on the remote.
I dont want to experience that scary situation again. It sucks if this has something to do with the app or hardware compatibility with my Xiaomi Mi6 phone.
Btw I did not experience any disconnection issue with the Phantom 4 Pro when using my Mi6.
2017-10-19
subbassline7
Flight distance : 75 ft
Greece
i bought a xiaomi redmi 4x and dji go 4 application doesnt open 2 days now...it opens the first page and stacks there...please help
2017-11-10
12Next >
