Battery will not stay on
18228 32 2016-11-2
fans86f3d666
Hello folks. This is first time on forum. Its been a couple of months sinse I flew my Phantom 3. Today I charged both of my batteries and all appeared good. Both batteries showed fully charged. When I pushed power button battery came on and showed all four lights green. Lights stayed on for about 5 seconds then went off. Both batteries doing same thing. Will not stay on. I have no idea what to do. I've gone through manual but no advise. Can someone help me. My Phantom 3 is just a few months old and hasn't been flown much.
2016-11-2
fans86f3d666
2016-11-2
DINGO DOWN UNDE
Flight distance : 3058816 ft
One press will tell you what charge level battery is at. To fire the battery up you hold down battery button for 1 second.....release and then press again for two or three seconds.........then all should be good!!
2016-11-2
Aardvark
Flight distance : 384432 ft
fans86f3d666 Posted at 2016-11-2 19:42
Hello folks. This is first time on forum. Its been a couple of months sinse I flew my Phantom 3. Tod ...
Push button once then release, then quickly push again and hold button operated for more than 2 seconds, that should do it.
2016-11-2
RSW
Flight distance : 116736 ft
Sorry that the replies you have received thus far do not address your question.
I have the same problem with one of my four batteries.
LISTEN POTENTIAL RESPONDERS: Short press followed by long press powers up the battery but it shuts off after a few seconds.
I don't have an answer but I found that when I try it several times is seems to stay on eventually. Sometimes I get impatient and switch to another battery.
2016-11-2
Geebax
RSW Posted at 2016-11-3 09:04
I have the same prob ...
The responders are correct, the OP does not appear to be using the correct technique to start the battery. Also, if you use the correct technique but the battery is not in the aircraft, it will shut down after a few seconds. To do it correctly, the battery must be in the aircraft firstly, then press the button once briefly and release, then press it again and the lights should march across from 1 to 4 then it will stay on.
2016-11-2
kirk2579
Flight distance : 37415 ft
RSW Posted at 2016-11-2 18:04
actuall I think they have,
if he is doing exactly as he says
he is not doing the second step as noted by previous posts.
quick touch once the release and then another touch till it fires up.
practice helps, I still mess up at times...after 2 years
can be in quad or outside quad.
if done outside quad you can then connect charger and "top Off" the charge.
Good luck and have fun flying
2016-11-2
Aardvark
RSW Posted at 2016-11-2 22:04
Bear in mind that potential responders may already have carried out this action hundreds if not thousands of times (I'm in the first category).
2016-11-2
Aardvark
Also if you watch the front of the P4, just above the camera gimbal housing, when you push and hold the power button the second time you will see the flash of a red LED inside the case. Once you've done it a few time it becomes 2nd nature.
2016-11-2
Aardvark
"I have the same problem with one of my four batteries."
So what happens with the other three, do they power up correctly ? If so then that might suggest a faulty battery.
2016-11-2
RSW
Aardvark Posted at 2016-11-3 08:38
So what happens with the other three, do ...
Yeah, I know. Once it powers on it has always performed fine. It just takes several attempts at getting it to go on, and again, it WILL turn on, but then it just goes off after a few seconds.
2016-11-2
DJI Natalia
Flight distance : 318 ft
RSW Posted at 2016-11-3 10:42
Yeah, I know. Once it powers on it has always performed fine. It just takes several attempts at ge ...
It seems interesting, may I know how long you have used the battery?  Please fully charge the battery, and if it can be power on properly, then check the battery info on APP page?
If it happens again next time, would you please record a short video for us? thanks.
2016-11-2
PanoF
Flight distance : 1219734 ft
Greece
As OP says Its been a couple of months sinse I flew my Phantom 3 So the battery must be  in a hibernation mode. I dont remember whats the solution for this, but i thing this is it.
2016-11-3
Aardvark
PanoF Posted at 2016-11-3 10:03
As OP says Its been a couple of months sinse I flew my Phantom 3 So the battery must be  in a hibern ...
LED around switch glows red if in hibernation mode. If in hibernation leave for 5 minutes and the light will turn off. Then recharge battery.
2016-11-3
RSW
DJI Natalia Posted at 2016-11-3 12:13
It seems interesting, may I know how long you have used the battery?  Please fully charge the batt ...
That battery has less than 1 hour flying time probably. An it hasn't been a showstopper yet as it will eventually come on. It is just a little disconcerting.
2016-11-3
DJI-Jamie
Flight distance : 112405 ft
RSW Posted at 2016-11-3 21:55
That battery has less than 1 hour flying time probably. An it hasn't been a showstopper yet as it  ...
Could you happen to provide a short video of how it's behaving?
2016-11-3
DJI-Jamie
As others have already mentioned, please ensure that you perform the following steps when turning on the battery:
- Push #1 to the power button is quick, providing the charge capacity information
- While the LEDs from Press #1 are still lit, press and hold the power button until you see all the LEDs light up again in succession.
2016-11-3
Hawks100
Flight distance : 134580 ft
Can i ask if these batteries are genuine DJI Batteries and not fake copies.
If they are the later,DJI updates have made them junk. {:4_181:}
2016-11-4
Geebax
Hawks100 Posted at 2016-11-5 06:35
If they are the later,DJ ...
That is not true, if they are not genuine DJI batteries, the aircraft will not accept them, much less carry out updates to them.
2016-11-4
RedHotPoker
Flight distance : 165105 ft
To top up an intelligent flight battery that is already above 95%, that double click and hold method applies as well.
When the battery is still turned on, plug it in to the charger, and it will begin to top up the battery to100% charge.
You need to outwit its brilliance... Haha
RedHotPoker
2016-11-4
Hawks100
That was my point
2016-11-4
Geebax
Yes, I see what you meant, your reply could be taken several ways.
2016-11-4
DJI-Jamie
Geebax Posted at 2016-11-5 06:04
That is not true, if they are not genuine DJI batteries, the aircraft will not accept them, much l ...
I concur with you. The unit won't even try to update.
2016-11-5
djiuser_8FOgXFqR0suY
HI Guys, I am so new to this.
I need some help please. We have the DJI 3 panthom advanced.
We have had it at the school a few years now. only was used once.
i have been asked to take over for a new projects and i cant get it ti start up.
Everytime i try and charge it, it comes on then switches of and this ongoing while plugged in.
i have done the one press and then hold ress and put the charger and it stays on but does not charge up.
i have held it down for 5 secounds and it returns with 4 solid green lights.
everytime its inserted into the drine, it comes onthen goes straigh awayy off.
please can you help.
it is a genuine from DJI. i think its out of warranty.
can any one help please.
2020-5-8
JetSam
Flight distance : 3462946 ft
i have held it down for 5 secounds and it returns with 4 solid green lights. ... it means useful charge of the battery, in its case a 100% useful life, that means the 4 green lights when pressed continuously 5 seconds
2020-5-8
JetSam
can you post a video showing the issue  ?
2020-5-8
JetSam
Check this also !!
2020-5-8
Hi Jetsam,
Thank you for this information. Il send a video shortly.
I have managed to get a new battery today. However I can't get the remote controller to get connected with the app.
I have downloaded almost all the dji ones from app store.
Did this on my android phone and ipad. Still says disconnected.
I have spent almost all day tying to figure ut out and I feel I am brain dead.
Just want to get this drone up and running for one project but feel. Like it's taking over my life.
2020-5-9
Geebax
djiuser_8FOgXFqR0suY Posted at 5-9 15:16
Hi Jetsam,
Just in case you have not got the right technique, you press the on button briefly and then release it, then almost immediately press and hold the button until the battery switches on. Note it requires TWO seperate presses. Exactly the same technique for switching on the RC unit.
2020-5-9
Hi,
Yes that's all working fine. I can even fly the aircraft using the RC. I can even control gimble to move around.
But just can not  onnect to the app
2020-5-9
JetSam
djiuser_8FOgXFqR0suY Posted at 5-9 23:46
Hi,
i would try reinstall the Dji app , a clean reinstall
2020-5-10
JetSam
djiuser_8FOgXFqR0suY what mobile device are you using?
2020-5-10
hi i have done this several times.
I have this installed on my Honor 10 huwai phone and also on my ipad 6
also have installed in on samsung tablet.
but all showing the smae. it will not give me enter camera mode but insted get how to connect option only.
I am so frustrated and feel i have wasted like few days of my life to to resolve this.
2020-5-10
