DJI-Ken
Flight distance : 1515312 ft
Jason, the playback of the flight does not show you had GPS lock at any time during the flight.
Where are you seeing this info. If it's from Healthy Drones then please disregard as a 3rd party website is not able to correctly decode the flight data.So since you never had GPS lock, the aircraft is free to drinft with the wind and it looks like that is what happened. Since ther was no GPS lock, I see you giving 100% input to make the aircraft go backwards. This input without GPS would make the aircraft go backwards really fast and when you let go of the stick the aircraft would still travel in that direction very fast and slowly decrease speed.The same for the 100% left stick input, it would go left very quickly and even though the stick input was only very quick, the aircraft would bank left and travel fast in that direction and slowly decrease it's speed.
Now, if you would have waitind for GPS lock then none of this would have happened, your first indication of a problem was you said you wanted to stop the airccraft to hover so you could adjust the camera. Since it was in ATTI mode, the aircraft never would have stopped and this is when things got worse. The aircraft moved exactly the way it was supposed to move. If it would have had GPS lock then whenever letting go of the sticks it would come to a stop instead of staying in the direction of the stick movement and moving quickly.
I just sent you the RC download tool.
After you understand that it was pilot error, please edit the post title.
