CADDJockey
Flight distance : 163934 ft
So, forgive my lack of knowledge and experience here, but I would think if there was a compass problem the drone would try to orient itself, so it would only spin around instead of fly in a straight or semi-straight path.
Correct me if I am wrong, but if it was an IMU error, then I can imagine all kinds of other drone behavior could occur - like flying off in a straight or curved path without user stick input. But I would think that would happen from the very beginning of the flight, at take-off.
If the drone is flying off in a direction, or spinning around, and not responding to user stick input, then it seems most logical that there is a communication problem between the RC, and the drone. Or, the app is interfering with the controller and causing the wrong signal to be sent to the drone?
Again, I don't know exactly how it all works, and I'm just throwing my own analytical thoughts on this problem. I really want to see these problems get resolved - and ideally before I get my Mavic .
Bottom line, I'm saying there could be multiple problems and we shouldn't assume all these problems are the same, or even related. For those who do fly and experience problems, you should pay close attention to how the aircraft is behaving, what you are doing, and be able to break each part into separate problems if necessary.
