Controller issue
1221 10 2016-11-6
ecophobic
This video explained some detail causes i havent heard of yet. If its true that could be quite a deal breaker...
http://www.youtube.com/watch?v=nMZ5fvDrpcE&sns=em
2016-11-6
F.C Drone City
Flight distance : 1909 ft
This is the first DJI drone that fly using WIFI . Does this technology have  something to do with this issue ? Check the WIFI -RC switch ?
I have  had a Mavic for 2 weeks now it flies smooth . The controller has no issues so far . I don't know maybe they rushed the productions & I'm afraid with this pressure & Complaints from people it will make DJI want production go fast and it might cause quality issues .
2016-11-6
dana5
Flight distance : 14354 ft
Interesting video. I think he has it nailed, but is wrong on one point. He thinks it's hardware, and not software, but I disagree.
When he is moving the sticks, and they get "stuck" off center... You will notice that all the values DO return to zero... I believe the stick reads correctly, but due to a software bug, is evaluated incorrectly, or is being onfluenced by another source. I do not believe that the magnetic controls are at fault. The problem is, in my opinion, in the firmware of the controller.
In short, if it was the magnetic sticks, tbe number values would get "stuck" along with the off center dot, but that is not the case.
2016-11-6
F.C Drone City
Wrong way to point the antennas . Just saying
2016-11-6
dana5
F.C Drone City  Posted at 2016-11-6 17:36
Anoyher good observation. One would think that everyone would know by now that this is wrong. They should both be up, and parallel.
2016-11-6
CabinPete
Flight distance : 98 ft
Wonder who's kid that was when he was showing the yaw flutter. Maybe he could have been a little closer.
2016-11-6
Mobilcams
Flight distance : 2907674 ft
So the sticks are sensed through magnetic sensors??
2016-11-6
BBMach
Not sure who made the first video but here is mine doing the same thing.  I had antennas in the proper place also.
Sorry for the bad video
2016-11-6
phatee
Flight distance : 36165 ft
i wonder.....does the joystick mode have anything to do with these issues?  I wounder if the people that were experiencing them would have the same result on a different mode.  Albeit, no one should have to change a mode to fix an issue, but just a thought.
if someone brought this up already and tested it out let me know.
2016-11-7
Jeromeo
Flight distance : 103369 ft
Can somebody with this issue try the simulator. It seams obvious than if it's a controler issue only, it should happen. Why nobody is trying. WE need to know. I don't have mine yet but i'm planing on loging few hours on simulator  before flying it.
2016-11-7
Shill Slayer
F.C Drone City  Posted at 2016-11-7 07:11
This is the first DJI drone that fly using WIFI . Does this technology have  something to do with th ...
The Phantom 2 Vision & Vision+, along with the Phantom 3 Standard & P34K all flew using WiFi technology.
2016-11-7
