The statement shown in the attachment is taken from page 49 in the Mavic User Manual. It clearly states certain altitude limitations regarding weak GPS reception. Based on the statement in the attachment, my question is as follows: What will happen when the GPS signal is suddenly weakened or lost while flying at an altitude above the "weak-GPS limited altitudes" defined in the manual. Will the aircraft suddenly descend to a lower altitude, possibly coming down into a tree top or structure, especially if you are flying with the Downward Vision System activated? In that case, according to the manual, your maximum altitude in that instance is only 16 feet! It would appreciate a definitive answer from DJI about this. |
