fansa84fe8a4
I may have hit a snag in the update.
Firmware part went okay. I removed the micro-SD card prior to doing it too. During the update the camera made a movement up and down so might help to remove guard. At 10% of the update process (after the long download one), the lights all went red on the bird and it seemed stuck, but it finally moved on and finished.
Restarted bird and went to check Flight Log in Assistant 2 on a PC. The "Save to Local" blue button was dim and I couldn't select any logs. There is some unexplained round button to the right of the "Save to Local" button. I don't know what it is for, but I pressed it thinking it might be "Save to Cloud" (Needs clarification as to what it is for??) and got the spinning wheel. Spinning wheel has been turning for 20 minutes now and the internal fan is on high speed.
Anyone know what that button is doing? Afraid to disconnect the thing now.
Tia.
