Phantom 3 Standard firmware v1.8.10 is now available to download!
Da Lata
Flight distance : 1008297 ft
Brazil
BobABooey Posted at 2016-11-10 07:15
What do u mean? Should i hook to dji wifi then switch to my house wifi?
Read post #11 and watch the movie on the first post!
Good Lock!
2016-11-9
BobABooey
Da Lata Posted at 2016-11-9 20:35
I use android and I had the same problem as you, I reconnected several times and the warning for u ...
i did try this before, Guess ill just have to keep tryin..
2016-11-9
userab78cc4d45
BobABooey Posted at 2016-11-9 18:26
I'm experiencing the same issue NO BANNER,App is up to date
2016-11-9
Devildog9999
Flight distance : 73865 ft
Same here - tried every which way, and no banner on 1.6.8/3.01(8)
@DJI - Is there anywhere to get the released firmware file that is no in Beta?
2016-11-9
BobABooey
Devildog9999 Posted at 2016-11-10 08:22
@DJI - Is there anywhere to get t ...
check post #21
2016-11-9
wmcvey
Flight distance : 904364 ft
You're suppose to connect to your drone's wifi first and load the Go app. Then disconnect from that wifi connection and connect to your home wifi, and wait and see it you get the update message, keeping the Go app loaded. Once you get the message you can download the FW to your device. Once downloaded you would then connect back to the drone's wifi to install.
2016-11-9
fansdcf34e53 Posted at 2016-11-9 23:01
I have the same problem. I do not see information about new ver in DJI GO  I tried everythi ...
Please try to link RC to aircraft and connect your mobile device with RC first then check the current firmware version in General settings-About.
Then change the network to WIFI or cellular and open the DJI GO app again.
You can download the new firmware.
Please let me know if this helps.
2016-11-9
fans0e105feb Posted at 2016-11-10 02:27
There is no banner in app. How can we update?
2016-11-9
Da Lata Posted at 2016-11-10 03:20
I did the update, check the txt file on SD Card (OK), I test flying the drone and like other user th ...
Please try to restart the DJI GO app and link your mobile device to RC again.
2016-11-9
BobABooey Posted at 2016-11-10 06:05
I only tried maybe 25 to 30 times. But I don't see any banner thingy.
Is my wifi supposed to look l ...
2016-11-9
2016-11-9
Photo Drone
Flight distance : 456201 ft
DJI Mindy Posted at 2016-11-10 10:45
Please try to link RC to aircraft and connect your mobile device with RC first then check the curr ...
Is this update for the p34k, I don't see the update as well ?
Thanks
2016-11-9
Photo Drone Posted at 2016-11-10 11:12
Thanks
Hi, it's for P3 standard. Not P3 4K.
2016-11-9
Photo Drone
I just had a look under the P34K firmware , which I thought was a p3s with a 4K camera.
but I guess there is no Firmware for us... Thought we finally got a break. Nope....
2016-11-9
Photo Drone
And when might there be a update for the P34K Mindy ?
2016-11-9
Photo Drone Posted at 2016-11-10 11:40
Sorry, I don't have any udpate information about P3 4K.
I'd suggest you keep an eye on our DJI weibsite. :-)
2016-11-9
djordan2
Flight distance : 377907 ft
markku.viitanen Posted at 2016-11-9 23:17
The new firmware seems to be downloadable in Phantomhelp website: http://www.phantomhelp.com/Phantom ...
I didn't see a banner, so I went to this page and downloaded the .bin file.  Then loaded it in the P3S and did the update that way.  I got a green light on the camera when it was finished, and the .txt file said "Success".  So I guess I did it correctly.  However, the Android app still says 1.68.8+.  I"ll try it all out tomorrow.  How to I get the app to read correctly?
2016-11-9
djordan2 Posted at 2016-11-10 11:59
I didn't see a banner, so I went to this page and downloaded the .bin file.  Then loaded it in the ...
Could you pleae try to reinstall the DJI GO app?
Then link your mobile device with RC and aircraft.
2016-11-9
fans4c281ddf
Flight distance : 71778 ft
Russia
Did the same and have 1.6.8+ is this correct?
2016-11-9
fans22aa3cea
Flight distance : 558173 ft
I downloaded the firmware.
Then I connected again to the AC, then started the firmware upgrade.
Then everything stopped after less than a minute: no message whatsoever.
I looked around and found no connection to the AC (but RC and AC were still tethered).
Then I powered everything off and on again and everything was back to normal except that the AC is still 1.6.8 and the App is still 3.0.2 but now there's no request for downloading firmware any more.
I also looked in the se card, and there's no trace of firmware file neither firmware update log.
What should I do?
2016-11-9
fans22aa3cea Posted at 2016-11-10 15:24
Then ...
Please try to reinstaill the DJI GO app and re-link the RC with aircraft and do the update again.
2016-11-9
imdilanvlogs
Sri Lanka
@DJI Mindy ,   I updated without any problem.. everything was completed. but after update my firmware version says : N/A   ..  DJI go latest version ( Android)  .. please help me to fix this...
2016-11-9
fans22aa3cea
DJI Mindy Posted at 2016-11-10 08:44
Re downloaded the app, then the FW update notice showed up again. I'm on latest firmware now. Thanks.
2016-11-10
imdilanvlogs@gm Posted at 2016-11-10 15:58
@DJI Mindy ,   I updated without any problem.. everything was completed. but after update my firmwar ...
Could you please try to restart your mobile device and then connect your mobile to RC again?
2016-11-10
fans22aa3cea Posted at 2016-11-10 16:05
Re downloaded the app, then the FW update notice showed up again. I'm on latest firmware now. Than ...
Glad to hear that. Thanks for the update.
2016-11-10
Da Lata
Brazil
DJI Mindy Posted at 2016-11-10 10:43
Please let me know i ...
I did but after that my DJI GO now show me N/A on version... before was 1.6.8+ and was working.
2016-11-10
fans4c281ddf
Russia
Dji mindy, can u tell me is it correct that the version of firmware shown in dji go app is 1.6.8+? Or it have to show 1.7.9?
2016-11-10
Da Lata Posted at 2016-11-10 17:40
Have you relinked the RC with aircraft?
2016-11-10
Saskebaby
Flight distance : 1017989 ft
Philippines
Thanks look great...
2016-11-10
fans4c281ddf Posted at 2016-11-10 17:44
Dji mindy, can u tell me is it correct that the version of firmware shown in dji go app is 1.6.8+? O ...
Please try to restart your mobile device.
Then connect your moible with RC and aircraft.
And check the version information again.
2016-11-10
fans4c281ddf
Russia
Thx, I'll try asap. Wait for feedback
2016-11-10
Da Lata
Brazil
DJI Mindy Posted at 2016-11-10 17:46
No... How I do that, I never did before
Note... I figure it ot already! now is relinked, but... see next post!
2016-11-10
Da Lata
Brazil
Ok I uninstall  app and reinstall, I relink the RC and phantom, I connect wiffii of android on phantom network and open the app... version N/A on about tab
2016-11-10
Da Lata
Brazil
OK DJI Mindy after waiting for you sweet hart I try to install again the new firm via SD...
This is the result on TXT file:
File on rooth - P3C_FW_RESULT_AB.TXT
========== 2014.01.01 00:01:40 remo-con disconnect======
Packet: P3C_FW_V99.99.9999.bin
Upgrading ...
Result: Success.
========== 2016.11.09 09:51:46 =====================
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3C_FW_V01.07.0090.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
File on H:\MISC\LOG - P3C_FW_LOG_AB.TXT
[00100117]========== remo-con disconnect. boot(1) ============
[00100243]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0xbd5c102a].
[00100278]Packet upgrade start...
[00100314]Packet checking...
[00100364]Packet vlink 01.06.0080 <-> 01.05.0070.
[00100429]Done.
[00100463]Version checking[1]...
[00100502][01 00][00] v1.14.4920 -> v1.14.4920
[00100539][01 01][00] v1.14.4920 -> v1.14.4920
[00100579][04 00][00] v1.44.0.0 -> v1.44.0.0
[00100651][03 05][00] v34.2.0.9 -> v34.2.0.9
[00100731][03 06][00] v2.4.15.5 -> v2.4.15.5
[00100788][09 00][00] v0.1.0.9 -> v0.1.1.0 need upgrade.
[00100866][12 00][00] v5.9.0.0 -> v5.9.0.0
[00100964][12 01][00] v5.9.0.0 -> v5.9.0.0
[00101055][12 02][00] v5.9.0.0 -> v5.9.0.0
[00101146][12 03][00] v5.9.0.0 -> v5.9.0.0
[00101266][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00101369][11 01][00] v1.7.0.0 -> v2.0.0.32, firmware v1.7.0.0 not support.
[00101403][11 01][00] v1.7.0.0 -> v2.0.0.32
[00101438]Done.
[00103473]Waiting for user confirm...
[00113520]Timeout, start upgrade automatically.
[00113587]Firmware upgrading[1]...
[00113629][11 00] Firmware upgrade start...
[00162444][11 00] Firmware upgrade finished successfully.
[00162503][09 00] Firmware upgrade start...
[00188497][09 00] Firmware upgrade finish without reboot.
[00218529][09 00] Firmware upgrade finished successfully.
[00218564]Done.
[00218598]Version checking[2]...
[00218639][01 00][00] v1.14.4920 -> v1.14.4920
[00218671][01 01][00] v1.14.4920 -> v1.14.4920
[00218714][04 00][00] v1.44.0.0 -> v1.44.0.0
[00218805][03 05][00] v34.2.0.9 -> v34.2.0.9
[00218882][03 06][00] v2.4.15.5 -> v2.4.15.5
[00218933][09 00][05] v0.1.1.0 -> v0.1.1.0
[00219017][12 00][00] v5.9.0.0 -> v5.9.0.0
[00219130][12 01][00] v5.9.0.0 -> v5.9.0.0
[00219207][12 02][00] v5.9.0.0 -> v5.9.0.0
[00219301][12 03][00] v5.9.0.0 -> v5.9.0.0
[00219428][11 00][05] v1.8.0.0 -> v1.8.0.0
[00219547][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00219582][11 01][00] v1.8.0.0 -> v2.0.0.32
[00219721]Packet upgrade finish successfully.
[00330095]========== 2016.11.09 09:51:46. boot(15) ============
[00330129]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0xbd5c102a].
[00330163]Packet upgrade start...
[00330200]Packet checking...
[00330241]Packet vlink 01.07.0090 <-> 01.06.0080.
[00330277]Record vlink 01.06.0080 <-> 01.05.0070 (flow = 0).
[00330312]Done.
[00330347]Version checking[1]...
[00330398][04 00][00] v1.44.0.0 -> v1.51.0.0 need upgrade.
[00330432]Done.
[00332466]Waiting for user confirm...
[00342498]Timeout, start upgrade automatically.
[00342584]Firmware upgrading[1]...
[00342665][04 00] Firmware upgrade start...
[00400489][04 00] Firmware upgrade finished successfully.
[00400526]Done.
[00400561]Version checking[2]...
[00400602][04 00][05] v1.51.0.0 -> v1.51.0.0
[00400633]Packet upgrade finish successfully.
[00014264]========== remo-con disconnect. boot(15) ============
[00014369]Packet [C:\P3C_FW_V01.07.0090.bin] detected, card sn [0xbd5c102a].
[00014538]Packet upgrade start...
[00014708]Packet checking...
[00014770]Packet vlink 01.07.0090 <-> 01.06.0080.
[00014824]Record vlink 01.07.0090 <-> 01.06.0080 (flow = 0).
[00014877]Done.
[00014940]Version checking[1]...
[00014992][04 00][00] v1.51.0.0 -> v1.51.0.0
[00015105][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015224][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015258][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015299][01 00][00] v1.14.4920 -> v1.14.4920
[00015331][01 01][00] v1.14.4920 -> v1.14.4920
[00015425][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015504][03 06][00] v2.4.15.5 -> v2.4.15.5
[00015590][07 00][00] v1.0.9.62 -> v1.0.9.62
[00015644][09 00][00] v0.1.1.0 -> v0.1.1.0
[00015742][12 00][00] v5.9.0.0 -> v5.9.0.0
[00015814][12 01][00] v5.9.0.0 -> v5.9.0.0
[00015904][12 02][00] v5.9.0.0 -> v5.9.0.0
[00016039][12 03][00] v5.9.0.0 -> v5.9.0.0
[00016072]Packet upgrade cancelled at version checking.
[00014135]========== remo-con disconnect. boot(15) ============
[00014171]Packet [C:\P3C_FW_V01.07.0090.bin] detected, card sn [0xbd5c102a].
[00014207]Packet upgrade start...
[00014248]Packet checking...
[00014296]Packet vlink 01.07.0090 <-> 01.06.0080.
[00014332]Record vlink 01.07.0090 <-> 01.06.0080 (flow = 0).
[00014365]Done.
[00014398]Version checking[1]...
[00014442][04 00][00] v1.51.0.0 -> v1.51.0.0
[00014558][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014677][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014712][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014748][01 00][00] v1.14.4920 -> v1.14.4920
[00014781][01 01][00] v1.14.4920 -> v1.14.4920
[00014838][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014922][03 06][00] v2.4.15.5 -> v2.4.15.5
[00015030][07 00][00] v1.0.9.62 -> v1.0.9.62
[00015087][09 00][00] v0.1.1.0 -> v0.1.1.0
[00015177][12 00][00] v5.9.0.0 -> v5.9.0.0
[00015239][12 01][00] v5.9.0.0 -> v5.9.0.0
[00015335][12 02][00] v5.9.0.0 -> v5.9.0.0
[00015409][12 03][00] v5.9.0.0 -> v5.9.0.0
[00015446]Packet upgrade cancelled at version checking.
And on the DJI app Keep showing me that the version is N / A
2016-11-10
fanscd256e3f
Flight distance : 175495 ft
maichelvnl Posted at 2016-11-9 20:32
Wow finally! So now the question is should I upgrade or wait until others have tried it first? I am  ...
You're going to want to wait because what if it creates a new glitch like loss of GPS or return to home just stops working and you lose it for now if it's working at least okay don't do it wait a while and get the reviews
2016-11-10
fanscd256e3f
i have the banner. I'm going to wait mine works pretty good I have a DBS mod and I get 3500 feet a buddy never upgraded to 1.68 same setup I have he gets 11000 feet but I don't want any other issues just in case my Phantom flies perfect not one issue every single thing is by the book couldn't be happier spent thousands on others and it never was this good
2016-11-10
Gerardo Rejec
Flight distance : 120141 ft
Da Lata Posted at 2016-11-9 15:33
Before update I did some flights with 700 meters distance, I do not test the complete range becaus ...
oh.. never mind then... your drone always worked to start with.  I was wondering if this update fixed the problem with the 50 to 70mm maximun range issue.
2016-11-10
fans4c281ddf
Russia
Yeah!!! Finally 1.7.9 on my phantom and good about page. Dji mindy when I deleted go app and make re link I've got "aircraft firmware unknown" at about page. But instead I've got "firmware download red message" and I successfully upgraded to 1.7.9 with no errors! I am very disappointed cause it's snowy winter here in Russia
2016-11-10
salvadorandrade
Flight distance : 109915 ft
Is it normal for the quad to beep during the update? 4 consecutive beeps
2016-11-10
fans4c281ddf
Russia
Yes it's normal and it's really sounds scary
2016-11-10
