A3 compatible with Zenmuse Z15/5D for Mark II??LB2?
1060 7 2016-11-9
fansc71345b6
Flight distance : 227621 ft
Hi there
I will really appreciate if someone could tell me if the discontinued Zenmuse Z15 5D for the Canon Eos Mark II (not the HD) is compatible with A3 Controller and Lightbridge2.. I would like to embark my "old" Eos 5D MkII into a S1000+ platform but I am unsure the gimbal would work with the latest electronics.. please help!
Thanks very much!
2016-11-9
DJI-Jamie
Flight distance : 112405 ft
No, the older 5D gimbal will not work with LB2. You would need to use the 5D III version.
2016-11-9
fansc71345b6
DJI-Jamie Posted at 2016-11-10 06:39
Thanks Jamie, then I've two questions..
1.- Then I have to use an A2 without LB, sending the signal throug analog 5,8? Can I use an A3 with a 5,8 trnasmitter?
2.-and does the 5D III version is compatible with the EOS 5D Mark II??
Thank you veeeeery much.
2016-11-10
DJI-Jamie
fansc71345b6 Posted at 2016-11-10 18:58
1.- Then I have to use an A2 without LB, sending the sig ...
Yes, you can use a 5.8 GHz FPV VTX. The EOS 5D II should fit on the 5D III, so you would be fine.
2016-11-10
fansc71345b6
Great... I've been looking somewhere in the Z15 5D III (HD) and doesn't says it is compatible with the 5D Mark II... But you say it should fit... May I trust you??...
2016-11-10
DJI-Jamie
fansc71345b6 Posted at 2016-11-11 01:13
Great... I've been looking somewhere in the Z15 5D III (HD) and doesn't says it is compatible with t ...
It's similar in weight in configuration, so it's something that you can try. If you have a local dealer, I would recommend bringing in your camera and trying it out. I understand that it is extra money, so trying it out in person may provide you with better assurance.
2016-11-10
fansc71345b6
Thanks for your cooperation.
2016-11-11
DJI-Jamie
fansc71345b6 Posted at 2016-11-11 20:30
You're welcome. Best of luck to you.
2016-11-11
