New firmware for Z3 has been released
5588 34 2016-11-10
DJI-Thor
Flight distance : 13602 ft
Over view
Firmware Version: V 1.9.1.40
What's New:
Improved video transmission stability.
Reduced gimbal vibration when used with the M600.
Fixed issue causing gimbal to be unable to carry out self-diagnosis when powered on at certain angles.
Compatible with Osmo Handle
Notes:
If update fails, restart and retry.
2016-11-10
fans0d3d8101
Flight distance : 337100 ft
Updated and waiting to test but first impression looks OK
2016-11-10
BIGDZ
Flight distance : 10200751 ft
DJI you did it up-on this new fw update for the Z3
It's now compatible with the osmo
2016-11-10
fans4ad0a808
Flight distance : 518166 ft
I can not find this new update on the DJI site all the firmware is from August. I get the new camera up date needed on my screen and it says see academy but I still don't see the new firmware.
2016-11-10
badbiggz78
Flight distance : 1444157 ft
will the update update the bird aswell or just the z3
2016-11-10
BIGDZ
anyone having issues uploading fw, I've done everything and the camera doesn't update
2016-11-10
DJI-Thor
fans4ad0a808 Posted at 2016-11-11 05:48
I can not find this new update on the DJI site all the firmware is from August. I get the new camera ...
http://www.dji.com/zenmuse-z3/info#downloads
You can find it here
2016-11-10
BIGDZ
DJI-Thor Posted at 2016-11-11 11:52
dji thor my camera will not upload new firmware, it doesn't do anything when I insert microsd card with the 1.9.4 update should i contact support? Ive done everything in the video above.
2016-11-10
DJI-Thor
badbiggz78 Posted at 2016-11-10 18:45
The firmware is in the gimbal of camera, not in the drone itself
2016-11-10
BIGDZ
DJI-Thor Posted at 2016-11-11 14:29
It doesn't respond, and now I have no transmission signal. Camera response to movement but screen is blacked out it didn't do that yesterday. Anyway I sent an email to support hoping to escalate an RMA I just got this camera back from DJI North America
2016-11-10
DJI-Thor
BIGDZ Posted at 2016-11-11 01:55
It doesn't respond, and now I have no transmission signal. Camera response to movement but screen  ...
Hi, you can try again, if this still happens, please send it in.
2016-11-10
BIGDZ
DJI-Thor Posted at 2016-11-11 15:08
Yeah it's not working plan on sending it back again, thanks for the assistants
2016-11-11
SkyHigh UAV
Flight distance : 2838921 ft
Update worked fine, cheers
2016-11-11
Jbundy63
Flight distance : 9583182 ft
Just downloaded and updated fine. Will know more in a day or two.
2016-11-11
ETA
Flight distance : 3032966 ft
I updated the Z3 firmware without issue and made some test flights.
With the follow parameters it was worse than before.   The image would not even stabilize at close range, it kept breaking up.
App 3.0.2
Aircraft: 1.9.1.30
RC: 1.6.0
Z3 Camera: 1.9.1.4
With the following parameters it worked much better.   Had only one instance of the image breaking up.  I flew at a distance of 700' away at an altitude of 150' AGL
App 2.8.7
Aircraft: 1.9.1.30
RC: 1.6.0
Z3 Camera: 1.9.1.4
DJI --  Should i send the camera back or wait for another firmware update.   I never opened a service ticket on this issue as i have been waiting for a FW update.
Thanks
Ed
2016-11-13
DJI-Thor
ETA Posted at 2016-11-13 17:07
With the follow parameters it w ...
Since the 2.8.7 app works fine for you, I would suggest you wait, because if it's an app issue we can always improve with a later app.
2016-11-13
ETA
DJI-Thor Posted at 2016-11-14 11:45
Since the 2.8.7 app works fine for you, I would suggest you wait, because if it's an app issue we  ...
DJI Thor,
Thank you for the response.
Are they working on fix?   Do they realize that there are still issues?
Thank you
2016-11-14
DJI-Thor
ETA Posted at 2016-11-14 19:57
DJI Thor,
Yes, we're working on it.
2016-11-14
RichJ53
Flight distance : 1837356 ft
DJI-Thor Posted at 2016-11-14 18:24
Hi Thor
I see this is mainly an update for the Z3 camera and not the Inspire 1 V2 X3. Will they be releasing another update that will help the Inspire 1 V2 with the X3 camera soon also?  We have been waiting for a long while
Rich
2016-11-14
DJI-Thor
RichJ53 Posted at 2016-11-15 00:42
Hi Thor
I see this is mainly an update for the Z3 camera and not the Inspire 1 V2 X3. Will they be ...
Sorry, I don't have information about this
2016-11-14
RichJ53
DJI-Thor Posted at 2016-11-14 22:00
Okay thank you for replying Thor
Rich
2016-11-15
AgriAerial
Flight distance : 1394639 ft
I tested the Z3 firmware update today and the spin up problem is not there any more (Thank goodness), but I had MAJOR issues with the live feed.... I checked the SD card and the video looked fine there (except for one instance).  I wish we could get the ongoing problems with this Z3 solved.  It has been way too long guys....
2016-11-15
SkyHigh UAV
Anyone had any problems returning the camera for a refund ????
2016-11-16
SteadyHoverCDN
Flight distance : 1327618 ft
fans4ad0a808 Posted at 2016-11-10 13:48
I found it here.
http://www.dji.com/zenmuse-z3/in ... te_search#downloads
2016-11-19
Farnk666
Flight distance : 1711394 ft
So, Z3 users - did this fix the problems with startup and live feed? What is the consensus?
I am hovering over the button for a large purchase of Inspire gear and would very much prefer specifying the Z3 over the X3.
2016-11-20
DJI-Thor
SkyHigh UAV Posted at 2016-11-17 06:13
DJI rarely allows refund after the refund window(7 days), unless the dealer is willing to take ( 30 days for Amazon and BestBuy)   This is according to my experience
2016-11-20
BIGDZ
DJI-Thor Posted at 2016-11-20 20:28
DJI rarely allows refund after the refund window(7 days), unless the dealer is willing to take ( 3 ...
3rd camera I got from you guys and the camera doesn't identifying fw 1.9.4. nothing happens
what should i do?
2016-11-21
BIGDZ
BIGDZ Posted at 2016-11-21 19:22
what s ...
happy to report I finally got the firmware to update. but what I realized, the beep sound.... d....d....d was so low I didn't even know it was upgrading. it was never that low before. Nothing was on at home, I noticed the faint sound and thought I was hearing things. Decided to let it run its course, and it updated. weird...
2016-11-21
P3T3
Flight distance : 701211 ft
Anyone else experiencing this... Firmware updated all appears well. My problem is (same as last firmware for Z3) the left wheel which is supposed to move the camera up and down, as it did on the X3, moves the Z3 left and right. It's annoying as I usually fly the inspire in the direction of a shot, I have to use the touch screen to move it up and down. What's up with this? I don't know of any setting to change it.
2016-11-27
ETA
P3T3 Posted at 2016-11-28 01:02
Anyone else experiencing this... Firmware updated all appears well. My problem is (same as last firm ...
Mine was acting the same way when using latest DJI go app.   Very annoying.  I have an ipad with an older version that i use when flying Z3 and it performs better.
I really hope they are working on these issues.
Ed
2016-11-27
P3T3
ETA Posted at 2016-11-27 18:23
Mine was acting the same way when using latest DJI go app.   Very annoying.  I have an ipad with a ...
Thanks for that info. I at now I at least know it's iOS firmware to call them about.
2016-11-27
fans73eed90f
So pumped the Z3 Finally works with the Osmo.  Am I stupid or does the Z3 lack audio.  I blew a video yesterday because I needed the zoom feature at a recital, but dangit, no audio'
2016-12-4
fans73eed90f
Any questions about Z3 working with Osmo, right here.
2016-12-4
DJI-Thor
fans73eed90f Posted at 2016-12-5 09:56
So pumped the Z3 Finally works with the Osmo.  Am I stupid or does the Z3 lack audio.  I blew a vide ...
Z3 was intended to be used on a drone, so no mic on it.
2016-12-4
Inspired_Mike
DJI-Thor Posted at 2016-12-4 21:01
Thanks, figured as much, will have to remember that when selecting osmo handhelds and running out the door.
2016-12-4
