BintangIO
Flight distance : 223852 ft
Indonesia
===== UPDATE =====
i use iphone 5s for upgrade firmware to 1.7.90 and success, and signal lost fix,
i use DJI GO App version 3.0.1 (Sony Xperia ZL). check firmware and firmware version : N/A, i upgrade to 1.5.7 and success
Packet: P3C_FW_V01.05.0070.bin
Upgrading ...
Result: Success.
but problem begin, DJI GO App always signal lost but i can calibrate gimbal, calibrate imu, relink RC, calibrate compass, i cant move gimbal using dial, i cant change mode, and firmware show latest update, first time i bought, this app show latest firmware, before upgrade, i using iphone 4s and show update firmware available, i dont upgrade using my iphone, after upgrade with sdcard and have trouble, i try upgrade to 1.6.8 and success
Packet: P3C_FW_V01.06.0080.bin
Upgrading ...
Result: Success.
and still signal lost, do be panic, i try update to 1.7.9 using sd card with dji go,
- remove sd card from camera
- format sd card
- copy fw 1.7.9
- turn on rc and Aircraft
- open dji go
- insert sd card with fw 1.7.9
and let see what happen, dji go app on sony xperia zl show new firmware available, i click but notif show, " failde to obtaine the information....... " oke dont be panic again,
so i turn off aircraft
i use my iphone 4s again for check firmware, i click academy hat maybe 5 second show menu about firmware, and i look this version is 1.2.4+, what the.... i try upgrade firmware to 1.5.7 - 1.6.8 - 1.7.9 and this app on ios show information about my firmware 1.2.4, what happen about upgrade firmware? failed? or this firmware for RC, i dont know, oke dont be panic again
i look dji go app on iphone 4s show new firmware, oke i download 1.7.9 from dji go, and finish download, this time for upgrade, i hope my drone can fly again, oke dji go notif to connect to rc wifi, oke i connected and what.................................... iphone 4s screen not support, i cant find upgrade button, oke maybe i must downgrade to 1.2.4
download firmware 1.2.4 and finish
- format sd card
- copy fw 1.2.4
- insert to sdcard slot
and......................
Packet: P3C_FW_V01.02.0040.bin
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
panic............
downgrade to 1.5.7
and .......................
Result: Abort.
totally panic.
i can show video from camera real time, rc indicator green, i can calibrate gimbal,imu,compass, i can relinking, i cant move gimbal using dial, linking button on aircraft show solid red led, cant downgrade, cant upgrade using android, cant upgrade using iphone 4s, i cant fly, i belive i can cry...
are you have same problem with me?
help me
thanks,
Bintang
