Hi Guy's, I am keen to here from anyone that hasn’t found a problem with Audio on the OSMO+. My own experience has been with using the External Mic that comes with the OSMO+, and with both the v1.1.0.30 and the latest firmware v1.2.0.40. After the Camera warms up (after about the first10min of continuous recording), the Audio either starts to crack up, or goes out of sync or stops altogether. You do not know this has happened until you review the footage, as the Audio Level indicator in the GO App shows the Audio functioning normally the whole time. The Audio generally returns once you stop the recording (even if for only 5 sec) and start it up again (i.e. New Recording file),... but once that new files gets beyond approx 6 minutes the problems occur again (and this can happen in as short as 3 min's, after the initial warm up). The reason I ask, is that I am really interested to know if it is just my unit or if this is the same or similar experience many others have had. Any incite would be greatly appreciated !
Cheers,
David
