Mavic Pro flying straight = left ?
2108 14 2016-11-15
JFXMedia
Often, probably 6 out of 10 times when I'm trying to fly dead straight I will notice on my screen the mavic is flying straight but veering left just a bit. So, on the screen, it will look as if I'm holding the left stick yawing to the left just a hair. Other times straight is straight. Does anyone else have this issue currently ?
Yea, it's calibrated, remote, aircraft, IMU.
2016-11-15
bigglyguy
Flight distance : 14196 ft
Malaysia
Well it seems compulsory to ask if you updated your firmware and changed your knickers recently?
2016-11-15
Wandering Cloud
Flight distance : 839633 ft
Yep, same problem here. Calibrated the compass, updated firmware etc... Still cannot fly in straight line.
2016-11-15
method007
Flight distance : 110449 ft
When you perform the IMU calibration, the drone has to be perfectly level.  So, your table, the floor in your house, outside on concrete, all of that won't work.  If you calibrate the IMU, something that rarely needs to be done anyway, and it's on an un level surface, it can cause the results you are having.
2016-11-15
bighi
Flight distance : 47455053 ft
Austria
I remember this issue back with the phantom 2 vision plus. It was eventually solved with a firmware upgrade. It hasn't shown up with anything DJI for a long time. Maybe it's back.
2016-11-15
DJI-Ken
Flight distance : 1515312 ft
Sync your records and what is your email and I will look at the flight.
And I gave you suggestions in the other thread you posted in about the same issue.
Try those, and if none work then preform an IMU calibration on a perfectly flat surface.
2016-11-15
DJI-Ken
Wandering Cloud Posted at 2016-11-16 01:43
Yep, same problem here. Calibrated the compass, updated firmware etc... Still cannot fly in straight ...
Make sure to unfold the arms before powering on as that will cause interference.
Make sure there's no metal around or in your pockets, and put the RC/phone on the ground several feet away from you then tap calibrate and walk over to the aircraft and perform the compass calibration.
2016-11-15
JFXMedia
DJI-Ken Posted at 2016-11-15 13:21
Make sure there's ...
Will do. Thanks
2016-11-15
JFXMedia
It is a current issue, drifting as well. I've calibrated everything multiple times now on perfectly flat surfaces. But it still will float to the left on straight cruises. I've seen this from several people now.
2016-11-16
phatee
Flight distance : 36165 ft
JFXMedia Posted at 2016-11-16 12:50
It is a current issue, drifting as well. I've calibrated everything multiple times now on perfectly  ...
have you tried different stick configurations? it's not a fix, but maybe this will work out once you do.
2016-11-16
Bikkel
Flight distance : 481175 ft
Had this problem also with my Phantom3 ADV, solved by an firmware update but that was long time ago
2016-11-16
bsvizuals8
I have the same issue. No amount of calibrating will fix it. The display always shows the right stick as off center by a few percent.
2016-12-11
fansae63899d
Flight distance : 361188 ft
I sometimes have the same issue. I need to adjust the straight flight then by moving the right stick in the direction to compensate the side movement.
I thought this happens because of some wind, but I also think that the GPS system should equate the wind.
2016-12-11
fansb3753e5a
Flight distance : 197828 ft
Same problem with my Mavic. Latest fw, recalibrate everything. Flies to the left. Screen shot of flight shows this quite clearly. Anyone had any luck solving this issue?
2017-2-4
fanseacc58a6
Flight distance : 694508 ft
Same issue here but on a p4p v2... I have the pvp2 pvp2+ p3p and all fly in a straight line. Mine yaws just like yours.
www.opspeculate.com
2019-2-23
