JBSonic
Flight distance : 779019 ft
Hey there, I would like to clear up some misconceptions about the Mavic's camera.
The Mavic Pro uses a SONY sensor, the IMX377, its predecessor IMX117 was used in the Phantom 4.
The sensor is actually pretty good, but there are compromises. The 1080p60/96 modes are known to have saw tooth shaped edges and moiré pattern,
which are both the effect of signal aliasing. The reason is that IMX377 cannot output full pixels and
need to work under the binning mode in the high frame rate more than 60fps. Although the sensor
tries its best to correct the aliasing.
Based on the Nyquist sampling law, the aliasing happens when the frequency of the signal passing
through the lens is nearly twice higher than the maximum sampling frequency of the sensor.
Unfortunately, the signal acquired by the sensor has already been corrupted and are unable to save.
The reason Phantom 4 owners dont see such an artificial phenomenon is because the
IMX117 can output 4KP60. The processor, therefore, downscales the frame from 4K to 1080p using
an anti-aliasing filter, which is superior to the internal combination of the sensor.
So why have this option for the Mavic in the first place? It is NOT for filming, it was included as a superior option for FPV flying and Googles, as it has lower latency.
If you want to film "slowMotion" then you will have to choose a larger bird like the Phantom or Inspire.
The Mavic Pro is for 24, 25 and 30 FPS filming only but it does a very good job at it for the size!
Hope this helped some people understand.
