Cetacean
Flight distance : 2528264 ft
Aloha marc,
You purchased the P4 Pro + (plus). It uses the GL300E controller with the 720p HDMI module, (that you can buy for the P3P, P3A, P4 and P4 Pro), already installed. But note the GL300E controller uses the 720p version of HDMI. The 720p version HDMI module on the GL300E controller is compatible with goggles and monitors, just like the other Phantoms noted earlier. The P4 Pro will be able to used the CrystalSky monitor, that has built-in 1080p HDMI, when it comes out later because it needs a device to work. With the P4 Pro you need to supply your own device like all the other Phantoms (later than the P2).
For those reading this thread who want a P4 Pro but also want HDMI, you can buy the 720p HDMI module from DJI ($100) and install it like you can with the other Phantoms noted above. The P4 Pro only has USB. The P4 Pro with the 720p HDMI module will also be able to use the CrystalSky monitor, with its 1080p HDMI, when it comes out later.
One difference between the built in screen on the P4 Pro + (plus) and the 5.5" CrystalSky monitor is that the 5.5" CrystalSky monitor has a way thicker frame that allows the built-in HDMI socket. The P4 Pro + (plus) screen frame is half the thickness of the CrystalSky monitors.
Hope this helps! I can be very confusing.
Aloha and Drone On! |
