Cetacean
Flight distance : 2528264 ft
Aloha ZOMBEE,
Yes, the P4 Pro Plus (+) has HDMI compatible with HDMI goggles. But, no FatShark goggles are truly High Definition. They are 800X600 at best. The HeadPlay HD ($250) is true 720p with a 7" display inside the goggle and the Glyph is well, it is the Glyph. It is hard to beat and expensive to.
The FatShark goggles are popular with racers because the analog transmitter has almost no lag time and that makes the lower resolution tolerable. But, camera operators need clarity, as in high definition, to see the images they want to capture. 720p resolution is even not enough for some.
You might want to see if you can change your order to the P4 Pro, not the P4 Plus (+), because the built-in screen will limit your HDMI resolutions to the 720p of the HDMI module it comes with. The P4 Pro will be able to use goggles and monitors, like the CrystalSky, that will have 1080p resolutions. When you change your order to the P4 Pro, also order the DJI HDMI module ($100). You can easily install it yourself and it will be compatible with current goggles (mentioned above), yet the remote controller will be able to use a 1080p display or device when they come out.
Alternatively, you can buy a GL300F remote controller for $312 later and use it with the CrystalSky monitor / device and get 1080p resolution. That way, you will still be able to use the 1080p built-in display of the P4 Pro + (plus) you ordered until the CrystalSky display comes out.
Hope this helps! I know, confusing, but it is confusing.
Aloha and Drone On! |
