Micro SD Card For Phantom 4 Pro
123
84046 91 2016-11-29
BLADE4
Flight distance : 1127530 ft
MNL5099 Posted at 2016-12-9 13:24
FYI, if you plan to record 4K at 100Mb/s on the P4P, you will need a U3 rated micro SD card, otherwise you won't be recording at 100Mb/s. U1 and Class 10 cards are not fast enough.
I put a little guide together for myself. All the information you need to know about SD cards and data rates with the phantom series aircraft can be found below. ____________________________________________________________________________
Very Well Done!
2017-9-22
jdjeff
Wollert Posted at 2017-3-17 12:09
I have the p4p and I bought this SD card: (San Disk Extreme 64 GB (3)  ) [view_image]  The problem is that the recording stops by it selfs and the video file gets corrupt. I have tried to record in 1080p 60 fps and 4k 60 fps. Both gets the same problem. I went back to the shop and got a replacement, but the same problem apparens.
I have tried:
I have the exact same card with the exact same problem.  I'm also looking for a point and click solution for the P4P.
I guess I'll try the Extreme Plus 32G from BH
2017-9-26
strongarm181
Flight distance : 229885 ft
Friends, going to bring this one back alive.
What's the best card to get for the P4P?
Seems to be the Sandisk Extreme and Extreme Plus  128 GB, I assume 128 is the max size?
With all these 4K videos my 64 GB card is filling quick and I've been using 2 Sandisk Ultra 64GB Micro SDXC UHS-I Cards.
Thoughts?! THANKS!
2018-9-8
FlyingUser
strongarm181 Posted at 2018-9-8 07:47
My P4P was shipped with a Sandisk extreme 16GB, and I had at home another, 64GB sandisk extreme card (same U3) both are perfect. You don't need huge capacity, because you move the content after every other flight anyway.
2018-9-8
P4P+_Brazil
Brazil
Sandisk Extreme 64 here too, great microSD card.
2018-9-8
strongarm181
FlyingUser Posted at 2018-9-8 09:12
I use it at work mostly for comparative use to show erosion so it's nifty to be able to pull old photos directly from the drone onto my iPad.
I guess I can try to 128.
2018-9-8
Yaron69
Ukraine
I use this one
SanDisk 64GB Extreme PRO UHS-II microSDXC
Bought it on B&H
2018-9-10
FlyingUser
Yaron69 Posted at 2018-9-10 05:02
I use this one
[view_image]
I love those USB3 hi-speed microSD readers, got one for my Lexar card, faster than any built-in card readers I ever had!
2018-9-11
RedHotPoker
Flight distance : 165105 ft
Nice little adapter...
RedHotPoker
2018-9-11
Michael Kemper
Flight distance : 1709583 ft
I use this one
[view_image]
I use the same exact one (from CDW I believe). Very happy with it.
2018-9-12
fans21d4f89a
Just bought PNY Elite-X microSD 256GB, U3, V30, A1, Class 10, up to 100MB/s for my P4P, it is working fine.
2019-11-30
fans21d4f89a
Wollert Posted at 2017-4-5 03:33
I bought sandisk extreme 64gb of a certified shop in Norway and exchanged the card 2 times, but got the same problem.
Have I bought another brand now, Lexar 633x. This card is even worse!!!, I insert the card en instantly gets the message error. ( Have tried to format to fat32, but stil only error message. Lexar 633x
2019-11-30
123
