Rc not connecting to tablet
845 5 2016-11-30
n2racen
After updating samsung tablet I can no longer connect rc to tablet. Have another samsung that still works. Have checked all settings under developers options on tablets and they are the same. Except and this is odd not a typo. Broken tablet keeps defauting to mtp protocol the one that is working is on charging protocol. Tablet worked fine before update.
2016-11-30
Have you tried to change another original USB cable?
If convenient, you could try to reset your phone to factory, then reinstall the app.
2016-11-30
n2racen
DJI Mindy Posted at 2016-11-30 22:17
If convenient, you could try to reset your phon ...
Its a tablet. USB cable works with phone and anothertablet, so I ruled out cable. Its tablet after latest update. I just dont know what happened?
2016-12-2
n2racen Posted at 2016-12-3 01:53
Its a tablet. USB cable works with phone and anothertablet, so I ruled out cable. Its tablet after ...
It's probably the latest update for the tablet is incompatible with DJI GO app.
Have you tried to reset your tablet to factory?
2016-12-3
n2racen
the fix ended up being in the way I power up the Rc and the tablet.
2016-12-11
n2racen
Yes tried to reset tablet. did not fix.
If I mess with the way I press power button on the rc and open and close app for about 15 minutes I can usually get it to connect. Wish I could find the actual issue! Very annoying to use in this current state.
2017-1-5
